Closed TopicStart new topic
> FS: Red Top Beams Single VVT-I Head Swap Kit
post Jun 5, 2015 - 12:29 PM
eazy2001x
Joined Feb 23, '05
Board Name: Eazy2001x
Means of Contact: eazy2001x@yahoo.com / PM
Description:
I'm cleaning out my garage.. I am never going to move forward with most of the stuff I have and just have way too much stuff. I am selling a complete Red top Rev 4 3S-GE Auto head kit. You will get the head complete with everything that bolts so it including the fuel rail, injectors, intake manifold, ETC? I will also include the ECU, MAF, un-cut celica SS3 wire harness, Coil's and head studs if you want them. I am firm on my price cause im really just letting this thing go at 500 Plus shipping. If your local enough ill even drive to meet you once payment is received.
There are two problems with this setup. The VVT-I solenoid plug pins were broken and needs to be repaired or replaced. The vacuum port where the brake booster line connects to was bent and needs to be straighten and repaired. There is a small hole where the bend was. You should be able to JB weld it and be fine, its really small. See pics below.
Don?t miss out on your once in a lifetime chance to get everything you need to swap this on your turbo or N/A/ If you were ever looking to Borden your usable power output here it is. Everything about this head is much more improved than the Gen 1/2/3/4 3S-G(TE/E) engine heads. This will also clear your strut tower.
For more information please see my threads:
BEAMS 3S-GE Head On A 5S Block (Need Help/Pics/Info!)
http://www.mr2oc.com/showthread.php?t=206777
BEAMS 3S-GE Head On A 5S Block (Need Help/Pics/Info!) - Part 2
http://www.mr2oc.com/showthread.php?t=434742
Built Gen 2 3S-GTE Head On Gen 4 3S-GE 11:1 CR Block With Gen 2 Oil Pump/Pan
http://www.mr2oc.com/showthread.php?t=580873
Pics:
Thanks,
Eazy
post Jun 8, 2015 - 8:59 AM
eazy2001x
Joined Feb 23, '05
475+shipping
post Jun 12, 2015 - 9:02 AM
eazy2001x
Joined Feb 23, '05
Todays special.. 390+ shipping for everything..
post Jun 17, 2015 - 10:44 AM
eazy2001x
Joined Feb 23, '05
I'm willing to do local pickup of up to 50 miles to save on shipping.
post Jun 20, 2015 - 8:55 AM
ricochet1490
Joined May 3, '11
From Ohio
Tentatively interested. Only because I have two of these motors already.....
Do you have any shipping estimates?
post Jun 20, 2015 - 9:04 AM
eazy2001x
Joined Feb 23, '05
QUOTE (ricochet1490 @ Jun 20, 2015 - 9:55 AM) *
It will have to be shipped in two packages. I can prob get it into one box. Based on all I ever shipped. I figure if I can get ot into one box.. The 100-105 range in the us ground, insured and tracking.
post Jun 20, 2015 - 10:30 AM
ricochet1490
Joined May 3, '11
From Ohio
PM'd
post Jun 30, 2015 - 7:24 AM
eazy2001x
Joined Feb 23, '05
Closed, Sold..
Lo-Fi Version Time is now: November 23rd, 2024 - 7:43 AM
