ST205 Brakes Upgrade |
Aug 25, 2015 - 6:01 PM |
Enthusiast Joined Jan 2, '15 From Philippines Currently Offline Reputation: 0 (0%) |
Hi guys,
There have been a lot of threads about this however, mine is somehow unique so i wanted to create my own thread. I have an AE101 Corolla with a 3sge rev3 motor in it and converted to ST202 brakes. I recently purchased a complete ST205 superstrut front and rear brakes from a for dirt cheap and since this is my dream brake setup I'm willing to go through all the trouble just to fit it in. A couple of things I need to put out here is that I'm from the Philippines so sourcing bits and parts may be a bit hard. Just for background here's how my suspension are coupled with everything just bolt in (no modifications done): Front: - ST202 JDM spec McPherson single pot caliper and rotor, knuckle and AE101 balljoints and brake lines Rear: - ST202 JDM spec rear single pot caliper and rotor and brake lines I cannot get a hold of a Cadillac Catera 2002 rotor. It's just not available in our country. My questions: 1. To get the caliper bolted in, can i simply thread tap the knuckle and bolt it right in? 2. Will i need 3mm spacers? 3. Do i need to change brake lines? (If yes, that's fine as i would really like to get ss lines on them however, from what car? Now for the rear i have no idea. If anyone has links that can help me. I have saved Culpable04's posts so i have that for reference however, if anyone else has any more info that would be greatly appreciated! Thanks 6GC! |
Aug 26, 2015 - 1:01 PM |
http://www.6gc.net/forums/index.php?showtopic=90206, lol. first topic
Aug 26, 2015 - 3:00 PM |
Enthusiast Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
if you converted to the ST202 hubs then you should just be able to follow the guide and go about it that way
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Aug 28, 2015 - 1:28 PM |
It's a 14% upgrade if you get the Avalon/Camry/ES300 twin piston calipers. They are direct bolt on to your ST202 brake bracket
-------------------- Group buy to replicate Narrow E series transaxle parts
Sep 10, 2015 - 12:58 PM |
Thanks for all your responses.
http://www.6gc.net/forums/index.php?showtopic=90206, lol. first topic Thanks for pointing that out. I've read that before and I will give it another go. if you converted to the ST202 hubs then you should just be able to follow the guide and go about it that way What if i am to use an ST205 caliper and rotor from a superstrut? That does make any difference? It's a 14% upgrade if you get the Avalon/Camry/ES300 twin piston calipers. They are direct bolt on to your ST202 brake bracket I could've gone that path however, I've bitten the ST205 brake set already. No going back! Heh. I think it would be best for me to take everything apart and see for myself as i really have no clue. Will post soon! Thanks. |
Sep 11, 2015 - 7:27 AM |
the ST205 Caliper and rotors only came on the superstrut so thats what we have all used for our conversions.
You wont be able to use the front rotor from the ST205 on the fronts though -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Sep 11, 2015 - 9:49 AM |
I think it would be best for me to take everything apart and see for myself as i really have no clue. Will post soon! Thanks. seriously dont waste your money anymore. Tigawoods has posted a true and accurate way to use the calipers. st205 rotors have to be reduced in size, and you need a machine shop to do it, and its not cheap. plus the cost of rotor, and difficulty obtaining. other rotors have been tried, and no such luck. ive bought wrx, and brz, and not good options. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Sep 14, 2015 - 10:14 AM |
refer to the sticky ST205 Brake Swap thread as we are slowly collecting more info on front rotor options
Sep 14, 2015 - 5:22 PM |
After reading through the guide and several forums. You guys are indeed right. Reason i got very confused with the guide as i saw various postings of rotors which at first i have no clue as to why but now the light has came down upon me!
Luckily, machine shops here in the PH are very abundant and having the ST205 rotors machined down to 300mm would be a breeze and will come cheap ($20 a pair i assume). About the rears. I read that the dust shields need to be trimmed down so that's ok. But what about spacers on the caliper holes? Can someone explain further? Here they are. They just look a wee bit sorry and having to inspect them I'm contemplating whether i should do a complete overhaul or just clean em out for now. |
Sep 22, 2015 - 1:19 PM |
the spacers are so that the disk will sit centered in the caliper IIRC
Sep 23, 2015 - 8:42 PM |
It's not a spacer, it's a 0.9mm hub-centric ring.
Any of the non-gt4 celica's have a 54.1mm hub bore on them, however, the GT4 has a 55mm hub bore. Why? no clue. So you need a 0.9mm ring to make the disk hub-centric. |
Sep 23, 2015 - 9:01 PM |
i did not use a hub centric ring. they fit snugly
Sep 24, 2015 - 3:27 PM |
It's not a spacer, it's a 0.9mm hub-centric ring. Any of the non-gt4 celica's have a 54.1mm hub bore on them, however, the GT4 has a 55mm hub bore. Why? no clue. So you need a 0.9mm ring to make the disk hub-centric. thats not what he was talking about. he was talking about the washers that go in between the caliper and the mounting hole This post has been edited by Tigawoods: Sep 24, 2015 - 3:28 PM -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Sep 24, 2015 - 8:14 PM |
It's not a spacer, it's a 0.9mm hub-centric ring. Any of the non-gt4 celica's have a 54.1mm hub bore on them, however, the GT4 has a 55mm hub bore. Why? no clue. So you need a 0.9mm ring to make the disk hub-centric. thats not what he was talking about. he was talking about the washers that go in between the caliper and the mounting hole oops. |
Oct 14, 2015 - 2:06 PM |
It's not a spacer, it's a 0.9mm hub-centric ring. Any of the non-gt4 celica's have a 54.1mm hub bore on them, however, the GT4 has a 55mm hub bore. Why? no clue. So you need a 0.9mm ring to make the disk hub-centric. thats not what he was talking about. he was talking about the washers that go in between the caliper and the mounting hole oops. Yes i was talking about the washers that go in between the caliper and mounting holes. Have not had the chance to install these yet but could well be in place by early November. |
Nov 2, 2017 - 1:01 PM |
Enthusiast Joined Jun 2, '16 From Toronto, ON Currently Offline Reputation: 0 (0%) |
It's a 14% upgrade if you get the Avalon/Camry/ES300 twin piston calipers. They are direct bolt on to your ST202 brake bracket I didn't even think the camry would have a twin piston caliber! I'm really going to start looking into these now. do you know if its just the 90's Avalon/Camry/ES300 twin piston or the early 2000's will also work? thanks for all your help with celica's bonzai. i don't think i would have been able to do have the stuff on my celica if it wasn't for you (and batman of course) |
Nov 27, 2017 - 11:42 AM |
do you know what stickies are?? check in the suspension/braking section..... the info is there...
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:49 AM |
