> Car won't start after manual swap!!, I'm so close...
post Aug 29, 2015 - 2:27 PM
JohnnyGat0519
Joined Jul 12, '15
From Iowa
Just got everything back together after doing the manual swap to my 95. Hooked up the battery and tried to fire it up.... no luck. Car cranks over just fine, but will not start. I did switch the ecu with the manual ecu out of a 99 gt. Don't know if that would have anything to do with it or not. It just plugged right in. Can't think of why it won't start. Anyone have any ideas????
post Aug 29, 2015 - 3:50 PM
richee3
Joined Jun 29, '08
From Denver
Are you not getting fuel or spark? There's a circuit opening relay on the side of the ECU. Try swapping that out with the old COR. However, I'd put my money on it being the crank position sensor. The '99 Celica uses a crankshaft position sensor that your '95 won't have.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 29, 2015 - 4:29 PM
JohnnyGat0519
Joined Jul 12, '15
From Iowa
QUOTE (richee3 @ Aug 29, 2015 - 4:50 PM) *
If it is the crank position sensor, how would I fix that issue? Just swap the ecu back?
post Aug 30, 2015 - 12:21 AM
mi645
Joined May 23, '12
From northridge,CA
Try the 95 ecu and it should still start. And richie is right, 99 models use a crank angle sensor, 95 do not, they run off the dizzy only. So if ur using a 99 ecu, it relies on the crank angle sensor for the engine to fire ignition, it wont spark without the sensor basically
post Aug 30, 2015 - 7:08 AM
JohnnyGat0519
Joined Jul 12, '15
From Iowa
QUOTE (mi645 @ Aug 30, 2015 - 1:21 AM) *
Switch the ecu back. Started right up!! So I'll be fine just leaving in my original ecu then?
post Aug 30, 2015 - 10:05 AM
it will run the car fine, but you will get a CEL for auto codes. look for a 95 MT ECU.
post Aug 30, 2015 - 10:51 AM
richee3
Joined Jun 29, '08
From Denver
QUOTE (JohnnyGat0519 @ Aug 30, 2015 - 7:08 AM) *
1998 Celica GT-
BEAMS Swapped.
post Aug 30, 2015 - 12:30 PM
JohnnyGat0519
Joined Jul 12, '15
From Iowa
QUOTE (Smaay @ Aug 30, 2015 - 11:05 AM) *
No CEL yet. But the o/d off light flashes
This post has been edited by JohnnyGat0519: Aug 30, 2015 - 5:23 PM
post Aug 30, 2015 - 5:55 PM
mi645
Joined May 23, '12
From northridge,CA
Just drive it. tongue.gif enjoy it
post Sep 1, 2015 - 7:24 PM
richee3
Joined Jun 29, '08
From Denver
Taylor has one for sale.
http://www.6gc.net/members/11483
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: November 24th, 2024 - 10:36 AM
