Enthusiast ![]() Joined Feb 21, '04 From Oklahoma Currently Offline Reputation: 0 (0%) ![]() |
What does the Celica use for tranny fluid? Tegs use regular 5w-30 oil. Was wanting to change it out. Also how much does it need. I have an 5 speed ST.
This post has been edited by 7A-FEces: Feb 22, 2004 - 11:56 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 12, '03 From Chatham, Ont Currently Offline Reputation: 0 (0%) ![]() |
Ive heard good things about penzoil synchromesh, suposedly it really smooths out shifting. I think you might need a little over 4 quarts? And Im not sure on the rating. This post has been edited by Uppitycracker: Feb 22, 2004 - 12:43 PM |
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) ![]() |
From Amsoil's website:
Picked 96 ST as I didnt know what year you have for sure, If different, go here: Amsoil lookup 1996 TOYOTA CELICA 1.8L 4-cyl VIN Code E 7A-FE FILTERS Oil Filter......SDF10 Air Filter......TS09 Fuel Filter......GF288 PCV Valve......HV105 Trans......TF117 BOSCH SPARK PLUGS ST Wire......B09822 Plug......B4417 BOSCH WIPER BLADES Driver side......B40921 Passenger side......B40920 Rear window......B40920 CHASSIS LUBRICATION 0 Fittings, 0 Plugs LUBRICANTS & FLUIDS Engine Oil Grade 1......SL Series 2000 Synthetic 0W-30 Motor Oil (TSO) SAE 5W-30 SYNTHETIC MOTOR OIL (ASL) Synthetic XL-7500 Motor Oil (XLF, XLM, XLT) Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil (HDD) Grade 2......API* Synthetic XL-7500 Motor Oil (XLF, XLM, XLT) Above 0°F......10W-30 Below 50°F......5W-30 Manual Transmission,.....GL-4 All temps......75W-90 Series 2000 Synthetic Gear Lube (TGR) Synthetic Gear Lubes (AGR, AGL, AGT, ALU, AGO) Manual Transmission,.....GL-5 All temps......75W-90 Series 2000 Synthetic Gear Lube (TGR) Synthetic Gear Lubes (AGR, AGL, AGT, ALU, AGO) Automatic Transmission,3-spd.....AF3 Synthetic Automatic Transmission Fluid (ATF) Differential, Front .....AF3[1] Synthetic Automatic Transmission Fluid (ATF) Fluids Power Steering Fluid.....AF3 Synthetic Automatic Transmission Fluid (ATF) Brake Fluid.....HB Hydraulic Brake Fluid, DOT-3, DOT-4 or SAE J1703 - Not Available Through Amsoil Click here for more information Clutch Fluid.....HB Hydraulic Brake Fluid, DOT-3, DOT-4 or SAE J1703 - Not Available Through Amsoil Click here for more information 1. Final drive for automatic transmission only. CAPACITIES Engine, with filter..........3.9 quarts[1] Cooling System, W/ AT Initial Fill..........6.9 quarts Cooling System, W/ MT Initial Fill..........6.4 quarts Automatic Transmission, Initial Fill..........3.5 quarts[2][3] Automatic Transmission, Total Fill A246E..........8.1 quarts A140E..........5.9 quarts Manual Transmission, From 5/95..........4.0 pints 1. Capacity shown includes filter. After refill check oil level 2. With engine automatic transmission operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed. 3. Findr will refill w/ trans through dipstick tube. TORQUES Oil Drain Plug.....25 ft-lbs Manual Transmission Fill Plug.....36 ft-lbs Drain Plug.....36 ft-lbs SERVICE INTERVAL http://www.amsoil.com/lit/g1490.pdf My Amsoil site |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) ![]() |
bg synchroshift... works pretty good
Enthusiast ![]() ![]() Joined May 8, '03 From San Jose, CA Currently Offline Reputation: 0 (0%) ![]() |
mobil 1 + lucas gear oil.
- aba |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) ![]() |
Good call, the Mobil and the Lucas are both great products. When people come into the Napa store I work at, I always point them in the direction of Mobil and Lucas products. -------------------- 95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE 02 WRX --> This is for speed - Borla Exhaust - TurboXS BOV - Custom CAI 02 Civic EX - MB Quart Reference 5.25" Components - Rockford MTX 8" Subs in the doors - Alpine Type S Rear Fills - 2x Alpine SWR-1042D Subs in a custom fiberglass box - Alpine F345 Amp for the front doors - Alpine M605 on each Type R - Phoenix Gold wiring - Alpine CDA-9855 Head Unit - Alpine Amp link - 2x Rockford Fosgate 1 Farad Caps - The best Viper 791 alarm install ever |
Thanx guys. So regular mobil 1 will work then? And 97 gtinkc is the 75w-90 the oil grade I need if I were to get amsoil? And what is 5.3 pints in qts?
Enthusiast ![]() ![]() Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) ![]() |
in my c52 (in a corolla, should be nearly identical for your celica st) tranny we put in 85w-90 gear oil..... it's a bitch to get in.... and we needed 2.7 quarts
when you fill it (the fill bolt is on the side of the tranny near that top, should be facing you when you open the hood) you should be able to just stick the tip of your pinky into the oil when you put it into the fill hole.... |
![]() Enthusiast ![]() ![]() ![]() Joined Sep 22, '02 From Detroit Currently Offline Reputation: 0 (0%) ![]() |
The factory recomended(sp?) oil is 75w90. And as far as pouring the oil, it's much easier with a 'beer bong' type funnel.
Guess I'll buy 3 qts then. Planning to do a swap so I'll just use the regular 75w-90 on my ST's tranny.
we used the pointed bottle and hooked a long hose up to it so that we could squeeze the bottle and the oil into it.... still took about 20 minutes though |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Sep 4, '03 From Twin Cities MN Currently Offline Reputation: 2 (100%) ![]() |
how much should i pay a shop to swap the tranny oil in my stick? I have no idea how to do this stuff
![]() ![]() -------------------- Car #3: 98 Accord LX- purchased 5/06, totaled 8/06
Car #2: 95 Celica GT- purchased 8/03, current daily driver Car #1: 01 Focus ZX3- purchased 5/01, sold 8/03 |
I wouldn't pay them more than it costs to get an oil change. It's about the same, except it takes longer to put the tranny fluid in and there's no filter to change. It's easy... there are two pretty big bolts on the tranny. One about halfway up the side (the fill plug) and one on the bottom (the drain plug). open drain plug, drain fluid, replace drain plug, open fill plug, put in fluid (it should take like 2.6 quarts - stick your pinky in the fill plug when you are getting close to see if you can feel the fluid level up to the fill plug yet).. replace fill plug and you're done. the hardest part is getting the filler plugs off. It's either a 24 or 26mm bolt I think. - aba This post has been edited by abatardi: Feb 26, 2004 - 11:51 AM |
Lo-Fi Version | Time is now: February 22nd, 2025 - 10:17 PM |
