Transmission doesnt engage at low rpm, any advice will help |
Jan 24, 2018 - 2:33 PM |
Enthusiast Joined Feb 5, '13 Currently Offline Reputation: 0 (0%) |
Hello everyone my celica has been running great for years after my rebuild and i always had a running rich check engine light. I recently now am having troubles sometimes but NOT ALWAYS engaging into a gear from either a dead stop and trying to go again or shifting into a new gear. Seems like when im going and driving it doesnt have any issues going into any gears but from a dead stop it sometimes wont get into the gear unless I rev up to about 1.5k-2k super embarassing at stop lights as you can imagine. Any advice would be appreciated. Let me know what you guys think that I can start checking.
Things I have checked. Transmission fluid is full and havent had to add any. No new check engine lights or codes. Thanks for your time! |
Jan 24, 2018 - 3:26 PM |
How many miles has it been since the rebuild? Supposed to change the fluid and filter every 25,000 miles or so.
Jan 24, 2018 - 4:15 PM |
How many miles has it been since the rebuild? Supposed to change the fluid and filter every 25,000 miles or so. Its been 15k miles since the rebuild. Its probably close to that time then . Could give that a try thank you! Also where is the filter? Are you just referring to the magnets in the transmission oil pan? |
Jan 24, 2018 - 6:24 PM |
Most automatics have a metal and mesh/foam filter that goes into the valve body. Which if it was rebuilt it's possible they didn't get the clutch friction spacing right and it's burning itself up... Check the fluid for grit or burnt smell. You might want to contact the rebuilder if there's a warranty it's still within and voice concern. It's also possible that solenoids or something in the valve body is sticking. This is why I don't like automatics, they're full of black magic.
Jan 24, 2018 - 8:43 PM |
I think the OP has a manual? if you cant shift into gears while stopped and the engine is running, your clutch is toast.
Jan 24, 2018 - 9:16 PM |
Under their profile pics it had an automatic, unless this is a different car and they didn't update it.
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:13 PM |
