Where the heck is the rear defroster relay? |
Dec 23, 2022 - 4:47 PM |
Enthusiast Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
Like the title says. My rear defroster has not been working for a long time. I checked that my contacts are good and the wiring running to the back is good. My fuse is ok and is getting power when the switch is on, so that seems to leave the relay as the culprit. However, I cannot for the life of me locate the damn thing. I’ve checked diagrams and they seem to indicate that it is somewhere under the left dash side with the fuses, etc. I hear it click when I turn on the heat, but still cannot locate it. Where is it!?!
Any help appreciated, thank you! |
Dec 27, 2022 - 7:58 PM |
Back of the left fuse panel is what I'm seeing. There should be 3 relays there with the defog being the bottom (or full right in the picture) one by itself.
https://www.ebay.com/itm/143934956658 -------------------- |
Jan 7, 2023 - 5:48 PM |
Back of the left fuse panel is what I'm seeing. There should be 3 relays there with the defog being the bottom (or full right in the picture) one by itself. https://www.ebay.com/itm/143934956658 Thank you so much! |
Lo-Fi Version | Time is now: November 29th, 2024 - 4:07 PM |
