> removing spoiler??
post Mar 9, 2004 - 1:55 PM
st202gt
Joined Jan 17, '03
From Fresno, CA
i was wondering show me how to remove the stock spoiler because i want to put my new spoiler on...
Replies (1 - 17)
post Mar 9, 2004 - 3:09 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
*bump*
i don't know how to get the plastic off
post Mar 9, 2004 - 3:16 PM
its VERY easy..you just kinda pop the plastic piece out enough for you to get at the one bolt under there, there is a rubber plug covering the other bolt, remove 2 bolts from each side, lift & done! biggrin.gif
post Mar 9, 2004 - 4:14 PM
Wild1Sushi
Joined Sep 16, '03
From So. Cali
This may be a thread for hatchback spoilers but does anyone know how to remove it for a coupe? Is the center post going to be an empty space once it's removed? Thanks a lot.
-Natalie
post Mar 9, 2004 - 6:54 PM
st202gt
Joined Jan 17, '03
From Fresno, CA
i mean after you unbolt the whole wing and how would you take off the glue..because my stock spoiler is a pain..i can't take off because of the glue holding it to the back..is there anyway just of making the glue to be un stick..so that i can pry off my spoiler?????/
post Mar 9, 2004 - 7:52 PM
there was no glue holding mine down, sorry....cant help ya there
post Mar 9, 2004 - 8:24 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
When i took mine off i just slowly pulled and the glue just split apart..of course then you have alot of glue residue on your car and a couple small holes from the bolts. Get out the "oops" (or any other sticky stuff remover) and put in some elbow grease! Just be sure to wash the whole area really well after you get all that junk off...so the remaining "oops" doesn't eat away at your paint over time.
post Mar 10, 2004 - 1:29 PM
st202gt
Joined Jan 17, '03
From Fresno, CA
finally got my spoiler out...i had to open the trunk and remove the inner part that has the center brake light..the whole part comes right off...there you will see the motor for the back windsheld wiper and there will be two screw that hold the spoiler...unscrew the two bolt and right come out the spoiler...
post Mar 10, 2004 - 1:37 PM
subsolo_21
Joined Nov 26, '03
From McKenzie, TN
-Natalie
To take off the coupe spoiler there are two screws in each of the three posts. You'll have to open your trunk and use an allen wrench to loosen the screws. There will be holes where the posts were so u'll need to do some bondo work and also to get the glue off I'd use 3M adhesive remover.
post Mar 10, 2004 - 8:48 PM
Consynx
Joined Dec 25, '02
newbie question: Where can i get bondo or putty to patch up the holes?
never done my own body work before, or else i would know this.
also, you said the plastic comes right off...
what part did you pull from, and are you 100% sure that you didn't strip anything by just pulling? i don't want a rattle from that plastic afterwards
This post has been edited by Consynx: Mar 10, 2004 - 8:52 PM
post Mar 10, 2004 - 10:20 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
bondoin' your holes- you'll have to get some of that wire mesh that they sell with the bondo, and find a way to get it in the hole, you just need something for the bondo to adhere to. then put one a layer, sand it flush with the rest of the trunk, repeat that step until you have a couple of layers. and no subs for a while, or else it'll turn out wrong
post Mar 11, 2004 - 1:32 AM
Wild1Sushi
Joined Sep 16, '03
From So. Cali
QUOTE (subsolo_21 @ Mar 10, 2004 - 6:37 PM)
Thanks subsolo_21!! I'll have to try it once I get my new spoiler. smile.gif
-Natalie
This post has been edited by Wild1Sushi: Mar 11, 2004 - 1:32 AM
post Mar 11, 2004 - 1:47 AM
Consynx
Joined Dec 25, '02
hmm, i was looking for a temporary fix...till i get them prefessionally fixed by having a piece of metal welded to it, and all
so I'm not about to do Bondo apparently :\
post Mar 17, 2004 - 4:25 PM
stylez112
Joined Jun 26, '03
From Carson, CA
The way I covered the holes in my car was using fiber glass on the back and bondo on the front. Good luck, it will take a while but you will learn a lot...
post Mar 17, 2004 - 4:47 PM
Consynx
Joined Dec 25, '02
i still can't get the damn piece of plastic off, it feels like it'll snap if i pull too hard.
post Mar 17, 2004 - 6:55 PM
just slowly pull it out....it basicly has these metal clips that are holding it. there are ment to be pulled off and then just snap back in.
post Mar 17, 2004 - 11:54 PM
Consynx
Joined Dec 25, '02
can you try to describe where they are at...
it would be best to pull from there as not to snap the piece.
post Mar 19, 2004 - 3:02 AM
neoklis
Joined Oct 24, '03
From Cyprus
Start pulling from the middle. Use swift moves and it should pop right off. try to pull from where the pins are at (Dont pull from the middle to for the pins at the sides- put your hands in there - it wont bite)
Lo-Fi Version Time is now: February 22nd, 2025 - 1:34 AM
