> +20 hp!!!!!!!!!!!!!, does anyone know about this
post Mar 9, 2004 - 7:24 PM
RoverGuy
Joined Oct 9, '03
From Indianapolis, In
can anyonelink to resistor ad thingy/ tell me what they are doing in this thing...or if it works?
Replies (1 - 19)
post Mar 9, 2004 - 7:28 PM
slipgun
Joined Jun 2, '03
From Annandale VA
they are screwing with your numbers going to the ecu so it puts in more gas and makes the car run rich, From what I hear it may actualy go faster, some say yes some say no, but I hear its not good for the car, I wouldnt get it.
post Mar 9, 2004 - 9:58 PM
94silverst
Joined Feb 20, '04
From Washington
This is a stupid product!! All it is is a resistor that is SUPPOSED to act like a horespower chip but doesn't do S***!! Someone is just selling a $.20 wire resistor for $20. DON'T BUY IT!!
post Mar 9, 2004 - 10:14 PM
snadman
From Minnesota, USA
You should really use the search feature instead of asking this...since this has been asked many times. But since I'm in a way good mood I'll just let your laziness live on and tell you.
It's a resistor put on the Air Intake Temp Sensor (not sure if that's the exact name for the sensor but it's the temperature sensor that goes in the intake box or in a hole drilled into your cold air/short ram intake). What it does is change the voltage so the computer thinks colder air is coming in even though it really isn't, and to compensate it pushes more fuel out. Sometimes this works, but I don't think it would benefit a 7AFE since everyone on this site says it already runs really rich. Honestly, if you want to send me 10 bucks I'll send you the resisitor mod and I'll keep the 9.75 that you just gave me as profit and do something with it...or you can send this guy 20 and he'll keep 19.75. Whatever you want...lol.
^^^ I hope you know I was being sarcastic, I wouldn't be that mean and steal 10 bucks from you like that. Just don't waste your time on cheap mods like this, if you can even call it a mod. Save your money for something worthwhile.
95 Toyota Celica GT
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- Alpine Type S Rear Fills
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
post Mar 10, 2004 - 9:34 AM
RoverGuy
Joined Oct 9, '03
obviously i wasnt going to buy it i just wondered acutally if anyone knew what size resistor it was...
post Mar 10, 2004 - 10:32 AM
SpedToe169
From Dallas, Tx
uh-huh
If you just wanted to know what size resistor it was why didn't you just ask that? And you obviously don't believe us if you want to know what size resistor it is because you're obviously going to try it. rolleyes.gif
post Mar 10, 2004 - 6:15 PM
RoverGuy
Joined Oct 9, '03
sure i would try it, i have tons of resistors and i was just trying to see if anyonw knew so that it would save me the trouble of going to a toyota dealer and finding out what the range of the sensor is...rich to lean....and probably more likely tapping into my coolant sensor since it has a lot more to do with my fuel air mixture than the tempeture sensor does since its a speed density system...i wasnt asking to be ridiculed it was just asking your opinion and if you knew...come on now...cant we all just get along smile.gif torrey
post Mar 10, 2004 - 6:16 PM
RoverGuy
Joined Oct 9, '03
plus with the implementation of my new exhaust and cold air intake a richer mixture could be ok.
post Mar 10, 2004 - 6:17 PM
Is that the air fuel mod? It just changes the voltage so ur ecu thinks ur getting colder air, its not going to be 20hp tho, what a crock.
post Mar 10, 2004 - 6:32 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
KILL THE nOOb
post Mar 10, 2004 - 7:09 PM
RoverGuy
Joined Oct 9, '03
ok so for those of you who don't know, colder air more dense...therefore requires more fuel....if the ecu thinks its getting more dense air(more air) it respondes with more fuel. but acually in an air density system(no Mass Air Flow Meter) the coolant temp sensor is the real mod...if rich engines run cooler...lean engines run hotter...if you make the ecu think the engine is a little hotter than whta it should be it will richen up the fuel mixture....but one thing. it WILL use more fuel.
post Mar 10, 2004 - 7:30 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (RoverGuy @ Mar 11, 2004 - 12:09 AM)
However, richer or leaner isn't more power (finding the perfect air/fuel mixture spots within the powerband does increase performance, but that's more complicated than simply adding more fuel). You don't make more power just with increased fuel alone. You'll need increased induction also. So what if the ECU "thinks" you have have colder more dense air... if you actually don't, the ecu will just spray rich and you're not gaining anything. I say again, more fuel alone does not equal more power.
FYI: The 7AFE runs fairly rich in stock trim...
This post has been edited by Kwanza26: Mar 10, 2004 - 7:31 PM
post Mar 10, 2004 - 8:12 PM
Fooling your ECU is BAD, thats why SAFCs being is debatable, they're fooling the ecu.
post Mar 10, 2004 - 9:04 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
those things are trash as a joke we put one on my friends civic it would rev higher and had better accel, but full tank of gas mysteriously disappeared and his car would stall and its a automatic.
Team 6gc 2005
post Mar 10, 2004 - 10:19 PM
snadman
From Minnesota, USA
BTW, RoverGuy...the reason I was beaing pretty mean was because this question has been asked before like 3 times most entitled "performance chip on ebay" so that's why you were getting ridiculed. And don't try it, get some real mods and some boost or something...then go get yourself a wideband O2 sensor and an ems or piggyback system so you can actually get some gains out of messing with your AFR. An intake and/or exhaust does hardly anything for our cars performance-wise. Why try and get one or two extra hp and risk messing up your engine?
This post has been edited by snadman: Mar 10, 2004 - 10:22 PM
95 Toyota Celica GT
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- Alpine Amp link
post Mar 11, 2004 - 12:21 PM
RoverGuy
Joined Oct 9, '03
ok...i see your point but your engine does breathe better b/c you have a better flow air filter on the front plus im eliminating 2 cats and a resonator...and hey if you know where i can get a real chip....please let me know...i would love that...i know i can search for it but sometimes people just like to talk about there cars to people who actually are doing the same things you are...isnt that what this community is all about...anyway...thank you for all of your input. torrey
post Mar 11, 2004 - 1:31 PM
The elimination of cats and air box and restrictive stuff just frees up HP, and you should do these things as a base for more intense tuning.
post Mar 11, 2004 - 3:30 PM
SpedToe169
From Dallas, Tx
You're oversimplifying this way too much. You cannot just put a resistor inline with one of the sensors and tune the car. This may have worked on older electronically fuel injected cars but its very unlikely that it will work on obd1 stuff and it sure as HELL isn't going to work on obd2 stuff. For instance, have you thought about what this does to timing? The ECU has control over timing as well and uses the saem sensors to figure out fuel and timing. If you want to tune your car, get an SAFC. Supersprint, there is nothing wrong with an safc, please pull your head out. If you're really serious, get a standalone ems. But please don't **** with **** if you don't know how it works (i.e. the stock ecu).
post Mar 11, 2004 - 4:26 PM
Said it before, i'll say it again...fooling ur ecu is BAD!
Your going to end up with detonation and then kaboom.
post Mar 11, 2004 - 5:22 PM
SpedToe169
From Dallas, Tx
First off, what experience do you have with this exactly? None? Thats what I thought.
Why do you think it would cause detonation? Poor tuning will. An improperly engineered car will. Bad gas can. But an SAFC does NOT cause detonation. Please get your facts straight.
Lo-Fi Version Time is now: December 3rd, 2024 - 10:18 AM
