> gt4 1/4 time
post Feb 2, 2003 - 5:40 AM
celicagt69
Joined Sep 22, '02
From wheat ridge, co
what do the 3 gen gt4 run above sea level
Replies (1 - 18)
post Feb 2, 2003 - 5:19 PM
Guest_Matthew_*
sea level? Why does that matter
I would say it depends on how much boost. If it has tires or not. And if they are aired up. J/k Depends on the driver plus the mods. But I would say about 13 secs or 14secs. That's just an estimate. I'm really not sure. I have never seen a gt-4 in real life. Nor driven one.
post Feb 2, 2003 - 11:25 PM
FallenHero
Joined Dec 26, '02
From Alabama
I think I remember hearing 6.6 to 60 in the 5th gen. Sounds a little high though for an AWD 200hp sub 3000 pound car.
post Feb 3, 2003 - 4:56 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
3rd gen? no clue...can't be too great though, since the GT4 seemed to have gotten faster in time
post Feb 4, 2003 - 5:22 PM
remjay
Joined Nov 13, '02
elevation matters, because the density of air changes at various altitudes.
do you mean 3rd gen g4 or a gt4 with a 3rd gen 3sgte?
post Feb 4, 2003 - 5:59 PM
Guest_Matthew_*
he said 3rd gen gt4 and obviously that would have the 3rd gen 3sgte. But i see what you mean. Maybe a st202 or 165,204 etc. with a 3rd gen 3sgte.
Again I would probaby the same as before. I bet around 5-6 seconds for 0-60
post Feb 8, 2003 - 8:55 AM
EC_Knightrider
Joined Dec 2, '02
From Gainesville, GA
sub 3000 lb car???
what are u talkn about??
post Feb 8, 2003 - 12:37 PM
QUOTE (EC_Knightrider @ Feb 8, 2003 - 5:55 AM)
sub 3000 lb car???
Are they heavier than that? I really have no idea since I'm not a fifth gen guy, but I would've guessed that, simply because my car weighs under 2400 lbs. from the factory. wink.gif
Edit: I just did some quick research, and it looks like the fifth gen Alltrac Turbo weighs 3219 lbs. wink.gif It looks to me like all of the sixth gens lost some weight from the fifth generation, because my ST coupe weighs 251 lbs. less than a fifth generation ST coupe.
This post has been edited by Coomer: Feb 8, 2003 - 12:45 PM
post Feb 8, 2003 - 11:31 PM
FallenHero
Joined Dec 26, '02
From Alabama
Man, I had no clue they weighed that much. They were a little fat weren't they.
post Feb 13, 2003 - 6:51 PM
celicagt69
Joined Sep 22, '02
sorry guys i ment what does the st205 run in the 1/4 i heard it runs mide 14's
post Feb 14, 2003 - 12:37 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
mine ran a 13.46 on 16 inch tires with just intake, irudium plugs, nology wires, HKS cam gear and a custom exhuast. didn't have a chance to run it after the HKS cam shafts and some of the other stuff.. will run it agian at the local track this summer and let you guys know what it runs with the new stuff I am doing.
If I can find the time slip for that run I will scan it and post it here
99 project version 3.0.. hello SEMA 2010 =)
post Feb 14, 2003 - 1:06 AM
FallenHero
Joined Dec 26, '02
From Alabama
with the 3's and Front wheel drive?
post Feb 16, 2003 - 2:27 PM
Consynx
Joined Dec 25, '02
13's sound really low
think about it, sure it has AWD, but the MR2 has close to same power...midship engine, with rear wheel drive...it hits 15's stock
i'd imagine that a GT4 should run 15's too
it's a bigger car, with a big more power, and of course more weight
the main idea is that is has a much greater potential than a ST or GT
post Feb 16, 2003 - 2:58 PM
trdcelicagt
Joined Jan 29, '03
From colorado
the mr2 runs 14's stock with less hp then the gt4 so the gt4 should run mid 14's
post Feb 16, 2003 - 11:50 PM
FallenHero
Joined Dec 26, '02
From Alabama
post Feb 17, 2003 - 12:23 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
I'll just go get on grand turismo and time it.
post Feb 17, 2003 - 2:04 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
that was with AWD
post Feb 17, 2003 - 2:26 AM
No0bOne
Joined Jan 5, '03
From Bay Area
Question: Do Supras(93-99) run 13s stock without basic setup?
NEVERSTOP, I think you could hit high 12's with that setup if you try again. It's possible.
Consynx, Mr2 is designed to be as a drag car so its handling isn't as good Celicas....think about it. As far as my guess I'm pretty sure that stock GT-4(6th gen) could run mid 14's stock.
post Feb 18, 2003 - 12:18 AM
FallenHero
Joined Dec 26, '02
From Alabama
I didn't think you had the AWD working yet?
Lo-Fi Version Time is now: November 24th, 2024 - 7:27 PM
