![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) ![]() |
I did a rear disc conversion. everything works fine except my parking brake. Do I need new parking brake pads? or what? Any help would be beneficial.
jeremy |
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) ![]() |
On the stock rear disk brakes, there are small drum brakes for just the parking brake. dunno if that helps any...
![]() Enthusiast ![]() ![]() ![]() Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) ![]() |
You might want to adjust the tension in the parking break cable. You just need to pry off that little divider where the shifter is and everything and there is a nut you tighten to increase the tension. If that doesnt work then it probably is those pesky brake pads in the small drum in the back.
I did adjust the tension in the inside of the car. I am still using the Parking brake cable from my ST. It is a little longer thatn the GT's... thniking maybe I need to put some spacers or something on the cable to shorten it.. Anyone think that it might work??
Enthusiast ![]() Joined Nov 5, '02 From Illinois Currently Offline Reputation: 2 (100%) ![]() |
you can also adjust them right at the wheel, theres a little spoked thing you turn and it make the two pads go out or in, its at the bottom of the two pads.
Thanks Rsos. I didn't read that part in the chilton manual. lol THey work fine now
no problem glad to help
Lo-Fi Version | Time is now: February 17th, 2025 - 1:25 PM |
