7A-FTE need info on INJECTORS, well........ |
Mar 29, 2004 - 7:48 AM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Well as long as i read about the injectors stuff, i know that i will need bigger injectors (or can i run stock ones at 10 psi?). Well i got Supras 7M-GE injectors (yellow top... ). And i know what 7A injectors are 13.9 ohm and 7M-GE are 2.9 ohm. Well i will need resistor pack to run them, right? but is this resistor pack is just ordinary resistors or there are more stuff that i dont know about? And is there a change to run resistors straight on the injector to get needed resistance for the ecu? Another Q is i got Supras 2 bar MAP. But i dont know ANYONE who used it sucesfully. How the hell i will tune my car with 2 bar MAP? Well for now thats it Thanks for the replays... -------------------- Ex celica owner - just a guy from other side of the pond...
Mar 29, 2004 - 2:13 PM |
Enthusiast Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
you can run the greentop 4a-ge (smallport highcomp) injectors.... they're 250CC and high ohm......
Mar 29, 2004 - 9:47 PM |
Enthusiast Joined Mar 8, '04 Currently Offline Reputation: 0 (0%) |
you can also use turbo probe injectors. i have two sets if you need some.
Mar 30, 2004 - 1:34 AM |
Well, i asked one thing, got answers that i know already..... But thanks anyway...
KnightRider - how much for the injectors? -------------------- Ex celica owner - just a guy from other side of the pond...
Mar 30, 2004 - 2:42 AM |
ANYONE????? Guys come one, or should i go to C.net to get the info???
Mar 30, 2004 - 2:14 PM |
Enthusiast Joined Aug 29, '02 From Dallas, Tx Currently Offline Reputation: 0 (0%) |
I think even with a resistor pack you're going to have power issues using the wrong impedance injectors. Just get the right ones!! It'll make your life a lot easier.
Do you know what size the stock injectors are? |
Mar 30, 2004 - 6:36 PM |
Enthusiast Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
cant you run the stock injectors.. they should hold up, shouldnt they??
Mar 30, 2004 - 8:29 PM |
Enthusiast Joined Dec 27, '02 From Sleep in Warren chill in clinton twp, works/school in detroit Currently Offline Reputation: 1 (100%) |
not if he's planning to boost his 7a up to about 10 psi -------------------- |
Mar 30, 2004 - 8:41 PM |
u can runnin on 8psi?? correct???
Mar 30, 2004 - 9:00 PM |
last time i heard zip only went up to 6 psi with his stock injectors.... i think not sure tho -------------------- |
Mar 30, 2004 - 9:09 PM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Doggy, the supra MAP is 2.2 bar you need a 3sgte one....There is no way around this. Not even the 5sfTe can run right with the 2.2.
-------------------- Member of Team 5sfTe
Mar 30, 2004 - 10:16 PM |
hmm.. ne 1 know ne knowledge of running 8 psi on your stock injectors.. i thought the only thing you needed to change was the fuel pump??
Mar 30, 2004 - 11:20 PM |
I think you will max out the flow way before that. Dont know for sure though.
Mar 31, 2004 - 12:29 AM |
Well, then i will have to get the Right injectors for sure... And that MAP sensore is total **** to? Hell.... well, how much does 3S-GTE map costs?
Adn our injectors stock are i think 215 cc or maybe bit more.... -------------------- Ex celica owner - just a guy from other side of the pond...
Mar 31, 2004 - 4:52 AM |
7/4a-fe stock injectors (at least in corolla's... i can't see them being different from an ae101/102 seeing how they use the same motor, ecu, and trannies) are 175cc......
Mar 31, 2004 - 7:19 AM |
so does ne1 know for sure if they would withstand 8psi?
Mar 31, 2004 - 10:03 AM |
It totally depends on what fuel pressure you had to run to make them work at that boost level. The amount of fuel the injector delivers is dependent on the flow rate of the injector (what you're talking about here), the fuel pressure delivered to it (controlled by your FMU), and the pulsewidth (controlled by the computer). You can add more fuel by increasing the fuel pressure but past about 100psi the injectors will start to hang open and cause problems. Also, if you reach about 95% duty cycle (by altering the pulsewidth with the SAFC) you'll start to have problems.
The easy answer is, if you don't know exactly what you're doing, error on the side of the bigger injectors. Its probably possible to make the car work with the stock ones, but an error could be fatal to the motor. |
Mar 31, 2004 - 3:16 PM |
You can find a map for 40-60 + shipping here. www.mr2oc.com www.alltrac.net www.thepartstrader.com -------------------- Member of Team 5sfTe
Lo-Fi Version | Time is now: November 30th, 2024 - 9:46 PM |
