> autostart in MT, so does anybody know how to do it ?
post Apr 6, 2004 - 11:51 AM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
yup like what the topic sez
Replies (1 - 19)
post Apr 6, 2004 - 12:10 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
autostart in Montana?? biggrin.gif i know coomer did it in his standard st. so you might wanna ask him.
post Apr 6, 2004 - 12:14 PM
rlan214
Joined Dec 27, '02
QUOTE (x_itchy_b_x @ Apr 6, 2004 - 10:10 AM)
This post has been edited by rlan214: Apr 6, 2004 - 12:18 PM
post Apr 6, 2004 - 1:49 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
If its anything like my talon, theres a fuse bypass you can do. It works already and thats how you can push start a manual. You just have to find the "clutch has to in" sensor's fuse and disable it. That of course may be different on the Celi. Ask the local auto store (not carquest or adv. auto but like speciality stores) that carry car alarms - they should know.
As for starting it in Montana, dunno - I live in Wisconsin.
post Apr 6, 2004 - 1:53 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
yea there is a bypass....one thing is ur car has to be in neutral to start it. u can get it at best buy the model number is 555u. all it pretty much does is send a pulse telling the car that the clutch is down and it will start...simple
post Apr 6, 2004 - 4:04 PM
FallenHero
Joined Dec 26, '02
From Alabama
Dude, dont get it. Everybody I knwo that has done this on a manual has started their car into a tree or something.
post Apr 7, 2004 - 12:20 AM
celimanST
Joined Nov 15, '03
From mississippi
From what I understand it is illegal in most states and besides it's just stupid and dangerous. redface.gif
post Apr 7, 2004 - 12:37 AM
tigernate29
Joined Aug 19, '03
From KY
Okay, just speaking from experience, you need to be really careful if you do install an automatic starter into a manual transmission. I did it, and it worked very well until I started it right through my fience's garage door. frown.gif Now I gotta buy a garage door and have my front end painted. Looking on the bright side though, I took the opportunity to install an Invader body kit. I thought, "hell, I gotta have bodywork done anyway, why not?" biggrin.gif
post Apr 7, 2004 - 8:27 AM
SpedToe169
From Dallas, Tx
Not if you always leave your car in neutral. You just have to think about what you're doing. I've had the remote start on mine for about 4 months and I've started it dozens of times with no trouble. I don't let other people drive my car (or I check it if they do) and I've never gotten into the habit of putting my car in gear when its parked. Thats what the parking brake is for.
As far as the clutch thing. I temporarily just put a piece of wire between the terminals of the switch harness. Eventually I'm going to make a bypass switch. The cruise control needs to think the clutch switch is there to work properly. Its just going to be bypassed unless i'm rolling down the highway and want cruise.....flip the bypass switch, hit the cruise button and there you go. Like somebody else mentioned you could totally use one of the additional pulse outputs on the alarm to do it, but thats too much trouble for me. I like not having the clutch switch at times. But then again, I'm used to being around race cars that are wired that way. Its really handy to not have to be sitting in the car to start it.
post Apr 7, 2004 - 11:58 AM
Yobbe
Joined Mar 12, '04
From Norway
Would it be possible to make a switch that only allows it to be started in neutral ? ... I guess you would have to get a little smart with the placement, but one should think that with a few microswitches this should be possible ?
post Apr 7, 2004 - 1:16 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
Real easy guys... get the 555u like playa said and leave it in neutral. I tell everyone to leave it in neutral. Never ever ever get into the habit of putting it into gear before you leave. There is a parking brake for manuals and thats why they call it the parking brake. The only reason I stress this is due to a turbo timer. People with those have to leave it in neutral, otherwise, you'll just have to wait the 1 minute while your car sits. You dont leave an auto in Drive when you leave do ya?
Sorry, i get a little flustered at the subject - i hate it when i hop into a MT and kill it as soon as it starts cause i thought it was in N
post Apr 7, 2004 - 4:34 PM
shid
Joined Jan 8, '04
From LA
Uhh, autostart like, push button on remote control car engine starts?
post Apr 7, 2004 - 5:22 PM
SpedToe169
From Dallas, Tx
Exactly. Its the poon. Especially if you live somewhere that it gets cold.
Amen Brotha. My compustar actually has a turbo timer built into it. Its pretty slick because i can cancel it at any time, but it automatically stays running until I hit the brake. No chance of leaving it in gear.
post Apr 7, 2004 - 7:40 PM
John, my car's cruise control(when I had it) worked fine with my clutch switch bypassed. Which switch did you tap into?
Also, I have a safety switch on my car, so that every time I plan on remote starting the car, I have to push this switch, which activates a loop on a SPDT relay and allows the car to remote start. Pushing the button reminds me to make sure the car is in neutral. wink.gif
And the only reason my car started into the cement wall of my garage was because when I put an interior panel back on, I accidentally put a screw through a wire for the safety switch, which grounded it out, in turn disabling the safety switch. It was pretty bad luck.
post Apr 7, 2004 - 8:16 PM
SpedToe169
From Dallas, Tx
Sounds like it.
The cruise thing has me stumped. It hasn't worked since I put the alarm in (I think I had a plug off the cruise ecu in the passenger side doing some wiring and never put it back...haven't had time to check it. But when it did work it would cancel the cruise whenever you pushed the clutch all the way in. Maybe it only cancels on a pulse trigger and not a constant trigger. I dunno. Right now I have it bypassed at the clutch switch on the pedal. I disconnected the switch and shorted across the plug (what the switch does when its triggered). Did you figure out a better way? I hope so. I don't really like how I did it.
post Apr 7, 2004 - 10:49 PM
shid
Joined Jan 8, '04
From LA
I assume an autostart in an automatic works fine?
post Apr 7, 2004 - 11:16 PM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
Yes, i have autostart in my celi, and it only took about 35 minutes to intstall myself...
-Ryan
AIM : FAQdaWorld
post Apr 8, 2004 - 12:07 AM
Pali_playa
Joined Apr 4, '04
From VA, USA
QUOTE (FAQdaWorld @ Apr 8, 2004 - 4:16 AM)
-Ryan
35 min???A damn u must be super-installer or sum ish. ive been installing RS alarms for about a year and usually tka me around 3 HRs
post Apr 8, 2004 - 12:51 AM
shid
Joined Jan 8, '04
From LA
Ryan, what did you buy to auto start it?
post Apr 8, 2004 - 10:43 PM
rlan214
Joined Dec 27, '02
so other peeps actually leave their car in gear hmmmm i nvr did that b4 oh well i guess ish betta to just leave it in neutral
soo pretty much i need a bypass huh
well im not the one that gonna install it but i just want to make sure that
the autostart will work cuz it can really get that cold in MI
Lo-Fi Version Time is now: November 23rd, 2024 - 7:56 PM
