> Indiglo Gauge Problem
post Apr 9, 2004 - 7:58 PM
mjmsoccer
Joined Aug 13, '03
From Greencastle, PA
I just got a set of Indiglo gauges and installed them without taking off the entire needle, just taking off the caps. I used double sided tape and taped down the gauges and whenever i put the caps back one the tach stuck at 3 K and the speedometer wouldn't work at all. Then I popped off the caps to try and they worked fine, but now i have red lights shining through the center where the caps were.
any suggestions on what to do? Thanks
Replies (1 - 7)
post Apr 9, 2004 - 10:53 PM
make sure the dubble sided tape isn't sticking out into the whole where the needles go, cause the caps hangdown lower than the needle and can get stuck on the tape, also make sure that the gauge face is stuck down nice and tight around the needle opening cause if its up even a lil bit the needle will stick
post Apr 11, 2004 - 1:05 AM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
yah the tape might be cause in gto be to high , my only get stuck when its cold , weird
post Apr 11, 2004 - 5:44 AM
Simmo
Joined Dec 17, '02
From England, UK
Have you removed the origianl dials or placed new one on top?
Remove originals and all will be fine. No more sticking.
post Apr 11, 2004 - 3:25 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
Team 6gc 2005
post Apr 11, 2004 - 4:43 PM
mjmsoccer
Joined Aug 13, '03
thanks for the help guys, im gonna take the gauges off and try taping them again, Simmo, i was told you couln't take off the original gauges confused.gif
post Apr 11, 2004 - 6:49 PM
neophile
Joined Nov 8, '02
From New Zealand
You're right, you don't need to take off the original gauges - the indiglo's are made to be overlayed over your originals.
Take a look at this post from back in february - it might be helpful.
post Apr 18, 2004 - 5:07 PM
Simmo
Joined Dec 17, '02
From England, UK
Hi Guys,
I removed the original dials, which are overlays themselves on the UK spec, doing this solved my problem of sticking needles. To remove I just snipped the original ones to the centre, took them off, used a pin with a head to replace the original needle rest.
Worked for me.
Hope this helps
Lo-Fi Version Time is now: January 16th, 2025 - 8:47 AM
