![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) ![]() |
a complete 3SGTE swap for ~1000???
sounds too good to be true. but if it works out, damn man, thats a hell of a deal. good luck, and let us know how what happens. btw: good call on a 3SGTE instead of a 4AGZE. the 4A is a great engine but no other Toyota engine compares to the 3S. |
what gen of 3s is that? I would guess 1st but that's not bad. 200hp and the potential for far more for only $1000.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) ![]() |
Lemme know how this all turns out, i might consider if it turns out pretty good. Im in Jersey, so its not that far, and i have a GT, so it should swap for less than an ST since the tranny/engine mounts, etc. all coincide.........I guess its something to keep in mind, maybe.
-------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
![]() Enthusiast ![]() ![]() Joined Feb 11, '03 From Phila, PA Currently Offline Reputation: 0 (0%) ![]() |
Where in central PA is this? I live 45 minutes north west of Phila in Pottstown. If you could tell me the place I can get this done that would be freakin splendid.
![]() Enthusiast Joined Jan 21, '03 From New Jersey Currently Offline Reputation: 0 (0%) ![]() |
That sounds like a great deal man, I'd love to stop by after yours is done and see what they can do for me. I'm in Central Jersey by Trenton so it wouldn't be too far of a drive and for something like that it would definately be worth it. But it does sound a little too good to be true so keep us all updated on how the situation progresses, i'm sure everyone will want to know. Best of luck
Enthusiast ![]() ![]() ![]() Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) ![]() |
dude, be careful. honda and acura swaps are a lot easier, because you don't have to change the wiring harness at all. hondas just bolt and drop in. i'd make sure they know how to do that before you get started. i've heard of acura/honda swap shops taking in a toyota swap and just completely messing it up, and then your car is in pieces in a shop that doesn't know how to fix it. bad. that would explain the low price, they don't think they have to do anything with the harness. This post has been edited by Charlie97L: Feb 13, 2003 - 9:06 PM -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
either way the engine he's getting is for pretty cheap, he could always have the labor done by someone else
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
That's an awesome deal, but be careful! Let us know what happens with everything.
![]() Enthusiast ![]() ![]() Joined Jan 9, '03 From Concord, NC Currently Offline Reputation: 0 (0%) ![]() |
Good luck and be careful, remember, you get what you pay for sometimes...
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) ![]() |
thats not entirely true. My friend has a 96 civic that had a b16 and a charger in it- he blew the motor about 2 months ago and just had a new b16 mounted into it.. same engine but different year. the shop which is know as one of the only shops in the US to do complete turbo kits on corvettes did his swap for him and they had a bitch of a time gettin all of the wiring harness to install onto the new motor... I actually just saw the car back on the road today so I guess they got it all worked out... newayz toyota swaps are alot harder to do than honda/acura swaps though -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
yep, you are right, there are some complications with certain honda swaps, thanks for clarifying what I said. ![]() -------------------- 1994 Lexus ES300
no prob... you where right tho they are pretty easy to do
edit: and there cheaper than $h*t!! my friend that I talked about before got his new b16 for 800 bucks! If 3sgte's where that cheap I would probably go through one a year! This post has been edited by NEVERSTOP: Feb 14, 2003 - 12:40 AM -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) ![]() |
Question, before you guys swap these engines, do you re-build them?
![]() Enthusiast ![]() ![]() Joined Aug 31, '02 Currently Offline Reputation: 0 (0%) ![]() |
Wow, that's pretty cheap... and pennsylvania isn't that far away... maybe a 3-4 hour drive....
yea like FallenHero said, do you build these engines up at all before you drop them in? I would think you might as well get the engine completly gone over and strengthened. It would give me more confidence running a high boost when that time would come. Im not sure what and how you strengthen the engine? Someone drop some knowledge please....
This post has been edited by Milds3vn: Feb 16, 2003 - 9:26 PM |
The 4a's have a really strong bottom end. All you would really need to do is re-build the engine. You know, take it apart, new gaskets, check everything out.
As for the 3s, it has a stronger bottom end... I hate you gt-guys and your 3s swaps ..l., |
Lo-Fi Version | Time is now: April 24th, 2025 - 3:20 PM |
