> Head unit turns off on its own..., then back on again...wtf?
post May 8, 2004 - 3:22 PM
XSTeknique
Joined Dec 21, '02
I just installed my turbo timer last week. I spliced into the 12V wire in my ignition harness for power to the TT. Now, while driving, the head unit turns off and then back on, usually when I push the clutch pedal down and idle to a stop. Other times, it just turns off while driving. At first the lights used to flicker and the tachometer needle would bounce on 1k, but that is no longer a problem. Now, it's just the head unit. Anyone?
Replies (1 - 5)
post May 8, 2004 - 3:44 PM
Andason
Joined Jun 26, '03
From Wisconsin
loose wire or an open connection?
i am awesome
post May 8, 2004 - 4:01 PM
XSTeknique
Joined Dec 21, '02
I soldered back all the wires. So I have no idea.
post May 8, 2004 - 4:06 PM
Andason
Joined Jun 26, '03
From Wisconsin
QUOTE (XSTeknique @ May 8, 2004 - 3:01 PM)
id check them. cuz if its pure random times it could quite possibly be a connection that is grounding out or something
i am awesome
post May 8, 2004 - 4:13 PM
XSTeknique
Joined Dec 21, '02
Thanks man, we'll see if I can figure it out.
post May 8, 2004 - 5:06 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
Is it just your head unit having problems? Do your interior lights dim at all? Like Andason said if its random its probably a loose connection. On my old car (mx3) when I was coming to a stop my lights would dim and my tach would drop a bit and come back up, I can't remember the exact solution but from what I can remember doing "hyper ground" setup helps.
Lo-Fi Version Time is now: January 11th, 2025 - 11:53 AM
