Redline ? |
Redline ? |
May 16, 2004 - 1:05 PM |
Enthusiast Joined Jul 11, '03 From Kennesaw, Ga Currently Offline Reputation: 0 (0%) |
Okay, I don't have a lot of time right now, and I did do a quick search, but couldn't find the answer to my question... maybe I'm not looking hard enough, but oh well...
My question is, what do yinz redline at? Everyone I know redlines at 6,400 rpm. Every aftermarket gauge has the same redline marking. Yet, my celi won't go any higher than 6,000 rpm, and redlines at about 5,700 rpm... Is this normal for a 97 ST Coupe? |
May 16, 2004 - 8:06 PM |
yup its normal and i hate it i wish we could rev higher...i've posted about this previously you can't by-pass the redline which stinks too
May 16, 2004 - 8:12 PM |
Enthusiast Joined Jul 12, '03 From Chatham, Ont Currently Offline Reputation: 0 (0%) |
is the 7afe really safe to rev past that? Last time I checked they arent exactly bulletproof engines. But hey I could be wrong.
May 16, 2004 - 8:16 PM |
Enthusiast Joined Sep 25, '03 From cranston RI Currently Offline Reputation: 0 (0%) |
mines normally doesnt go about 5700 - 5800 rpms....
but i also have an auto.... -------------------- |
May 16, 2004 - 8:28 PM |
its not bullet proof but our engines can handle alot...i think stock you'd be fine up to around 6k-6.3k rpm but i'm not sure cause who honestly spends more than 3 seconds above 5.5k?
May 16, 2004 - 9:44 PM |
Enthusiast Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) |
There's no more hp gain up there, correct?
-------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
May 16, 2004 - 10:08 PM |
ok i'm not sure....this is just a guess but i'll say no not really....you'll just be able to pull a little bit longer and keep up the momentum
this is just a guess |
May 16, 2004 - 10:09 PM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
yea there is no point in raising redline on our cars unless you do other things, like hige compression and cams that are ground to make peak power at a higher rpm the only thing you might get from raising redline on an otherwise stock car would be to achieve higher top speeds, which doesnt make sense since a stock celica cant go much faster than what it does at redline in top gear. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
May 16, 2004 - 11:09 PM |
I've done 125, and it just couldn't push it through the air anymore, but it wasn't on redline either, i think i was at 5900
May 17, 2004 - 1:20 AM |
Enthusiast Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
my 4a-fe would hit the fuel cut at 6200 rpm's... racer25, with a modified ecu, has taken his 7a-fe up to 8,000 rpm's and the valves started to float... these are non-interference motors
May 17, 2004 - 1:23 AM |
The 7A block has been proven to rev up to 8000+ rpms and live on stock rods and crank. Club4AG guys have built race spec 7AGEs and run them at and beyond 8000 rpms all the time... mind you, that's with relatively stock 7AFE rods and crank. The reason not to rev... well, you'll get valve float if you rev a stock head like that (GE or FE)... and it doesn't make any power past that without performance cams. As for my 7AFE... the rev limter is at 6700 something... -------------------- "It's ok to be naked girl... I'm an artist!"
May 17, 2004 - 7:04 AM |
Enthusiast Joined Sep 18, '03 From Dirty Jersey Currently Offline Reputation: 0 (0%) |
i have taken my 7afe past 5700!! mine doesn't start to cut out till 6500. i normally only take it up to 6 when driving though.
May 17, 2004 - 7:16 AM |
Enthusiast Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) |
doggy need to post that video again..
May 17, 2004 - 2:37 PM |
hey philly how'd you get it to rev that high, i get fuel shut off at 5800>? how did you bypass that?!?!?
May 17, 2004 - 4:09 PM |
WTF is yinz? -------------------- |
May 17, 2004 - 7:44 PM |
that was completely stock! i haven't touched the fuel system of ecu.
This post has been edited by PhillyGuy086: May 17, 2004 - 7:44 PM |
Lo-Fi Version | Time is now: December 4th, 2024 - 2:05 PM |
