> My A/V system in about a week.., Touchscreen monitor, g4 powerbook, SNES,
post May 17, 2004 - 5:24 PM
shid
Joined Jan 8, '04
From LA
Xenarc 700TSV touchscreen monitor- also hooked up will be an SNES with controllers rerouted to the centor console. Wireless keyboard- no need for a mouse (touchscreen..).
Putting the head unit where the quarter window and top controls are- moving THOSE under the dash whole.
The computer- a g4 550 mhz powerbook, is gonna be used for mp3s, NES, Genesis, and PS1 emulation- not to mention DVDs, divx (NARUTO!), etc etc etc. I plan to mount the computer sideways under my seat, so that I can change DVDs on it smile.gif
So... what do you guys think? Any comments? questions i need to think of? suggestions? etc etc?
This post has been edited by shid: May 17, 2004 - 5:25 PM
Replies (1 - 19)
post May 17, 2004 - 5:35 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
thats great man, u're doin exactly what i planned to do. I'm going for the lilliput screen. if u go to LCD Forums u can find out which one is best. Good luck man.
Team 6gc 2005
post May 17, 2004 - 5:52 PM
shid
Joined Jan 8, '04
From LA
Wow! thanks for the link drocay. All this stuff about powerbooks and touchscreens.. mmmm fun reading.
EDIT: after reading the forums for a bit it seems like I made the best choice- spending more money for a better screen. They've fixed the touchscreen problem and everything..
This post has been edited by shid: May 17, 2004 - 6:19 PM
post May 17, 2004 - 6:42 PM
ghostdog
From ny to philly
how are you molding the screen into your dash. I've done some research on this and might have some links that could help.
post May 17, 2004 - 6:49 PM
shid
Joined Jan 8, '04
From LA
Ghost, thats one of the things I'm researching now- I would appreciate any links u could offer smile.gif
post May 17, 2004 - 6:55 PM
Cormudgen
Joined Jul 31, '03
From GA
they layout you plan on your dash is identical to the one I have been planning
keep us updated
cormudgen
post May 17, 2004 - 7:02 PM
shid
Joined Jan 8, '04
From LA
The rundown on difficulty I am expecting so far is this:
monitor fit @ old head unit area: EASY, This area just needs to be expanded in order to fit the screen. I'll know more when I have the unit in front of me, but I'm not expecting major hassles here, just cutting. Behind the unit there's ample space for the little over an inch depth required. Mountings going to be a pain- and will probably be accomplished by a strange assortment of mismatched L brackets and the like screwing into the old head unit screws.
head unit fit at old switch area: MEDIUM/HARD , a little sanding again; the most difficult part is going to be widening the SIDE of the console to make it fit.. if you look at the PS picture, it overlaps a little- most difficult part is going to be to GET RID OF THE STOCK AMP- which right now is blocking the head unit from fitting in depth wise- once thats gone tho, it'll fit easy. A small plastic piece might need to be affixed to the edge of the head unit to cover up a half centimeter hole- but thats it. Faceplate might even still be removable. Only downside being, CD's wont be able to be put into the unit when cars in park due to gearshift. I might change the gearshift later tho to a smaller one, so even that only problem disappears. Volume knob is still easily reachable too!
relocating convertible switches to under dash: Simple as HELL- the area around each switch comes out even.. we don't need to make new switches.. wires will need to be extended- only problem; and thats not too difficult.. right? smile.gif
Overall, I've heard of some people taking many many months to complete a system like this. Which strikes me as odd. I don't plan to take more than 3 days once all the parts arrive.
post May 18, 2004 - 12:52 AM
snadman
From Minnesota, USA
If you're doing custom fiberglass holdings or whatever...it may take longer...but I'm with you...as long as you actually have some kind of focus on the task u should finish within 3 or 4 days.
95 Toyota Celica GT
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- Alpine Type S Rear Fills
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
post May 18, 2004 - 6:31 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
most people don't make a brackets or holders they dismantle the screen and mold the frame into the dash and then they just screw it right back together.
Team 6gc 2005
post May 18, 2004 - 1:56 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
dude that is awesome, id put an snes in too!
- Ryan
aim: rkgreen04
post May 18, 2004 - 2:07 PM
Einhander
Joined Oct 23, '03
From ky
I hope you plan to mount that g4 powerbook solid, the stock harddrives in mac's don't like to be bounced around, and are very fragile. I've had to replace the drives in both my laptops. Just giving you a heads up on that. But the system will look amazing.
post May 18, 2004 - 2:08 PM
shid
Joined Jan 8, '04
From LA
I'm mounting it under my seat to the seat- so however solid that is.. haha. and I won't be using the g4 iternal as my main drive- I'll be using an external firewire for that.. so the main one won't be accessed that many cycles per minute hopefully.
post May 18, 2004 - 2:42 PM
Einhander
Joined Oct 23, '03
From ky
just listen for what i now call the "death click", your mac will make a slight clicking sound comming from the front of the case to the left of trac-pad, few days later you get the flashing question mark. Only thing i found that fixes it for more than a day or so is replacing the harddrive. But good luck.
post May 18, 2004 - 3:42 PM
shid
Joined Jan 8, '04
From LA
I know the death click, it's happened on my IIsi, my 8600, and my G4
--Sean
post May 18, 2004 - 10:39 PM
macavely
Joined Nov 4, '02
why not take the computer apart and relocate everthing into your glove box.. and take you moniter and take that apart also and just mold the casing into your dash then screw the screen back on..
post May 18, 2004 - 11:39 PM
shid
Joined Jan 8, '04
From LA
Err, powerbooks are notorious for being hard to take apart etc- basically, removing 2 screws is the road to a dead computer
post May 19, 2004 - 5:46 AM
Yobbe
Joined Mar 12, '04
From Norway
Have you considered a Mini ITX computer ? I guess its not worth considering if you already have a G4 you can use, but you can get a mini ITX for about 350-400 USD that runs on the 12 volt directly from the car.
What kinda screen are you going for ? Got a link ? I have been wondering about buying a Lilliput touch lcd for my car but it would be neat to hear from someone how has seen it (or any other screen) in action smile.gif
post May 19, 2004 - 10:16 AM
shid
Joined Jan 8, '04
From LA
I also WANT a mac in my car smile.gif I'm buying it off my friend for 350-400 USD. haha. it has a boken screen- thats why.
It's a xenarc 700TSV http://www.onehitwonders.com/700tsvusb.html or http://www.xenarc.com/product/700ts.html
I have NOT seen the lilliput screens. I've seen the xenarc in action- it was sweet. The older models were said to have glare problems- but the one I saw had no such problems. The xenarc costs more money than the lilliput- supposidly because they use better screens (the lilliputs screens are recycled?)
Go to the link Drocay posted- its mostly about the lilliput and xenarc screens.
post May 22, 2004 - 8:59 PM
KAMiX
Joined Mar 4, '03
Nice biggrin.gif what are you planning on playing on the snes? lol!
Secret of mana?
Rock n' Roll Racing!?!
Illusion of gaia?
hehehe oh the memories...
post May 23, 2004 - 2:37 AM
shid
Joined Jan 8, '04
From LA
Uhm, F-zero. DUH! hahaha
Lo-Fi Version Time is now: February 20th, 2025 - 2:00 AM
