engine motor mounts, need parts#,who knows |
May 26, 2004 - 12:16 PM |
Enthusiast Joined Sep 5, '02 From Puerto Rico Currently Offline Reputation: 0 (0%) |
Hi everyone,Im in the procces of the 3sgte engine swap into my 7afe 1994 celica and I need the original toyota part# for the front,rear,passenger and driver motor mounts from 1994 toyota celica GT-S with 5sfe engine,because thath the engine mounts that Im goona use.Please part#s for all the 4 mounts.
May 31, 2004 - 3:50 PM |
Enthusiast Joined May 23, '04 From Meridian, MS Currently Offline Reputation: 2 (100%) |
are these the best mounts for the swap, i'm doing it too
May 31, 2004 - 6:42 PM |
12360-74030 front
12371-74410 rear 12372-74450 LH 12362-74330 RH -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
May 31, 2004 - 7:20 PM |
Enthusiast Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) |
I have a question, nt to steal your thread.. But The motor i bought has the mounts on it.. Its the 3s-ge .. not the beams.. but thopse mounts should work for my st? right? Thanks
Jun 1, 2004 - 2:53 AM |
Enthusiast Joined Mar 2, '04 From Little Rock, AR Currently Offline Reputation: 0 (0%) |
im pretty sure as long as you have 94-99 gt motor mounts, that block will mount up |
Jun 2, 2004 - 7:26 PM |
the toyota deal said one of these is wrong 12360-74030 front 12371-74410 rear 12372-74450 LH 12362-74430 RH it is going to cost over 300 for all of these from the dealer where else should i try to get these i tried local auto parts stores but those numbers didn't transfer into anything -------------------- |
Jun 2, 2004 - 7:37 PM |
Enthusiast Joined Dec 2, '02 From Portland, Oregon Currently Offline Reputation: 0 (0%) |
Two words....Junkyard Celica =)
Jun 3, 2004 - 8:20 PM |
Enthusiast Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
you can get urathene mounts, go to your local performance shop.
they can used the old mount and pop the urathene insert in. |
Jun 4, 2004 - 7:48 AM |
12360-74030 front 12371-74410 rear 12372-74450 LH 12362-74430 RH do you know which one? 12362-74430 RH this is the wrong one...the right # is 12362-74330 This post has been edited by presure2: Jun 4, 2004 - 7:49 AM -------------------- Former Team 5SFTE pro member ;)
Jun 4, 2004 - 11:00 AM |
Enthusiast Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
it doesn't matter if you have a ST or a GT.
The FRONT and BACK mounts are identicle. You can use your existing ST mounts. The only thing you have to buy are all 4 Motor Mount Brackets and the Driver and Passenger side mounts for a GT. That's less money you have to spend. |
Jun 6, 2004 - 10:18 PM |
they told me 12362-74330 RH is wrong that its 12362-74430 and it $197 ok so all i need is driver and passenger side mounts -------------------- |
Lo-Fi Version | Time is now: November 25th, 2024 - 5:35 AM |
