> V6 6gen Celica, has any one done it ???
post May 27, 2004 - 1:16 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
has anyone seen this done ???
I was told it was a very easy swap to make + that motor makes alot of tq & TRD also makes a super charger where you can get 9pounds or boost!
N/A-198HP
F/I-238HP
3 Pages V   1 2 3 >
Replies (1 - 19)
post May 27, 2004 - 1:51 AM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (Punch @ May 26, 2004 - 11:16 PM)
N/A-198HP
F/I-238HP
What engine are we talking about here? And it really depends on the configuration and positioning of the engine. If its a inline 6 like a supra then like anyone here will tell you it probably isn't going to happen. If its a v6 then I dont see it being to much trouble.
post May 27, 2004 - 2:03 AM
aaronc222
Joined Sep 22, '02
From Detroit
It's the v6 from the mid-late 90's Camry/Solora. I've seen the writeup on the 5th gen that did the swap and they were very happy with it. Since then I've lost the page for it, but I'm pretty sure that it's someone on celica.net. I believe they said it was about the same price as a 3S swap.
post May 27, 2004 - 4:36 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
There's a lot of custom work involved... and you need to know what you're doing. There will be wire work, custom fabrication, and relocating some accesories. The TRD s/c most likely won't fit... the V6 is a fairly tight squeeze...
Engine code is 1MZFE btw... shares the same series tranny as the 3SG series...
post May 27, 2004 - 7:59 PM
Four
Joined Aug 30, '02
From tacoma WA
yeah it can be done and isnt super hard but isnt as easy as a 3s swap. search celica.net's forums to find out about it.
also some guys drop a v8 into a 5th gen alltrac converted it to RWD. o and they also twin turbo'd it.
post May 27, 2004 - 9:06 PM
wind
Joined Nov 4, '03
From Vancouver, Canada!
why waste the money and add the weight? just pop in a 3sgte.... it would still rape a v6 and v8 and save gas too
post May 27, 2004 - 9:31 PM
Mike
Joined Oct 22, '02
From Toronto
I've seen a v8 in a 5th gen
It was posted a while ago
post May 27, 2004 - 9:35 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Ie to have the power of the v6, being n/a an all... but for the hassle i would rather go with the 3s, also cause the wieght...
post May 28, 2004 - 12:19 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (Digndoug @ May 28, 2004 - 2:35 AM)
FYI... the 3SGTE isn't much lighter than the 1MZFE. All alluminum...
post May 28, 2004 - 12:33 AM
boosted_K2
Joined Aug 30, '02
From Michigan
i wouldnt be surprised if the 1mzfe is actually lighter, do you have any info on that kwanza? id be very interested to see.
cast iron block + iron alloy head = very strong but very heavy.
No but I don't buy it
Cause I'm...
post May 28, 2004 - 11:21 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (boosted_K2 @ May 28, 2004 - 5:33 AM)
The only info I have is based on common sense... ;] I'm willing to guess it's actually lighter also... The only thing that makes it bigger, is it has 2 more cylinders, and has a slighty larger bore. All other components are actually smaller (shorter rods, smaller crank, etc...) What I do know is... the K20A2 weighs a lot less than a 7AFE... cause the K20A is all aluminum (all forged internals also).
post May 28, 2004 - 3:46 PM
creis
Joined Jan 10, '04
From Shoreline, WA
is it posible to drop a jetta VR6 in a 6th gen. that would be decent. 180hp, plus its hella light, i know a guy who put one in a cabiro, and its just rediculously fast. since i'm probibly stuck getting a new engen that is my first choice.
post May 28, 2004 - 4:12 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
lmao .. firstould you even think about putting a vw engine in a toyota.. second off.. the v6 camry would be better anyways...
post Jun 1, 2004 - 9:39 PM
97GTinKC
From KC
QUOTE (creis @ May 28, 2004 - 1:46 PM)
Sure it can be done, the answer to that question is always yes, The correct question to ask is "How much time and money will it take to make it fit?" and the answer to that question should scare you in this case.
This post has been edited by 97GTinKC: Jun 1, 2004 - 9:39 PM
post Jun 2, 2004 - 9:50 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
I talked to the Adrian(did the swap). he told me that it wasn't all that hard. He and his buddies did it himself and they aren't mechanics. He used a 97 solara engine. 200hp and torq. He also said it is lighter than the 3sgte b/c of the all aluminum. I think it cost him like 6 grand when all said and done.
post Jun 3, 2004 - 7:55 PM
RedSunCelica
From San Diego CA
QUOTE (Jeremy1210 @ Jun 2, 2004 - 7:50 PM)
6 grand for a celica raper damn! thats actually worth it and with the light weight and low end torque that it makes itll be a nice drag car smile.gif
post Jun 6, 2004 - 1:19 PM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
and the v6 will beat the 3sgte stock
post Jun 6, 2004 - 3:53 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
QUOTE (red_94gts @ Jun 6, 2004 - 11:19 AM)
what is your reasoning with that?
This post has been edited by Doge: Jun 6, 2004 - 3:54 PM
post Jun 6, 2004 - 5:10 PM
Jeremy1210
Joined Dec 16, '02
Well the V6 adrian Used had 200hp and 200 lb/ft. I really think that it would be a very close race. Very driver dependent on outcome IMO.
post Jun 7, 2004 - 12:46 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (Jeremy1210 @ Jun 6, 2004 - 10:10 PM)
The 3SGTE has a much better torque/powerband...
FYI: V6 5 speed Camrys and Solaras are only clocked at mid-low 15's... with the Celica's weight... they's be a second faster at most...
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: January 10th, 2025 - 7:54 AM
