> Problem
post Jun 3, 2004 - 2:53 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
Ok so brian and me changed my oil today.... read the convo and help me out please!!!!!
NunCHUCKSNinja: my car vibrates a lot now
NunCHUCKSNinja: and acts weird
Sortafamous: what do you mean?
NunCHUCKSNinja: when i accelerate it vibrates and when i was at idle it was changing rpm
Sortafamous: hmm
Sortafamous: it was 10w30 right?
NunCHUCKSNinja: yep
NunCHUCKSNinja: i think the vibration might be partly because the muffler was bent and now it hits the back bumper
NunCHUCKSNinja: and also it lags a little bit when i accelerate
Sortafamous: im lookin around
Sortafamous: but i dunno
Sortafamous: it might be that stop smoke stuff
Sortafamous: cause its so thick
I was lazy so I didnt feel like typing the whole situation so that convo sums it up.
Replies (1 - 19)
post Jun 3, 2004 - 3:13 PM
Guest_Jason_*
The answer is b.
post Jun 3, 2004 - 3:15 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
That helps man
could somebody give me a good answer?
post Jun 3, 2004 - 3:17 PM
Guest_Jason_*
Okay, honestly I don't know what your asking. What oil to you normally use? Is it always 10w30? If so, that has nothing to do with it. If you normally use oil completely different from that, you ****ed up. If thats the case, changing oils on your engine can strain oil gaskets (i think thats what it is, i'm having a blonde moment), and can make them leak because they swell if you use different oil types.
Do you have a new intake? Do you still have a stock intake box? If you have a new intake, it could be that bogging you up, if you have an intake already, forget I mentioned this. If you have a stock intake box, open that and make sure its not flooded with oil.
[edit]
I'll add more. If your stock intake box is filled with oil, you blew an oil ring. You may have done that regardless, again because of changing the oil weight.
This post has been edited by Jason: Jun 3, 2004 - 3:19 PM
post Jun 3, 2004 - 3:21 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
he has an intake and has had one for a while
post Jun 3, 2004 - 3:26 PM
Guest_Jason_*
If there is thick smoke coming out, I bet he blew an oil ring. If thats the case, your car is worthless I believe.
post Jun 3, 2004 - 3:42 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
there is no smoke coming out, just the problems he posted in our convo
post Jun 3, 2004 - 3:51 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
Yeah ive had the injen short ram intake for over a year. I get my oil changed at tires plus every time this is the first time I have changed it myself. So im not sure what oil they use, but most likley it would be 10w30 wouldnt it?
post Jun 3, 2004 - 3:58 PM
Andason
Joined Jun 26, '03
From Wisconsin
wow the celica is such an easy car to change the oil on. you should be slapped for ****ing that up some how
i am awesome
post Jun 3, 2004 - 4:09 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
how could i **** it up when i mightve just put a different oil in the car than the car is used to. we did everything right. you should be slapped in the face for being such a jackass
post Jun 3, 2004 - 4:12 PM
Guest_Jason_*
The thing is, your oil rings can swell if you change the weight of the oil, normally it doesn't unless you keep changing it, but sometimes it can happen with a one-time thing. Its not that you ****ed up, its more that you may have had that one-time occurance and the oil rings didn't like the different oil.
post Jun 3, 2004 - 4:19 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
So what should I do if thats the case?
post Jun 3, 2004 - 5:38 PM
spunky393
Joined Apr 22, '04
From illinois
sounds like he went from a senfetic (spelling-sorry) oil to a regular everyday oil, and he isn't use to it, or the engine really really didn't like it. Before i switch over to senfetic, my car idled a little bit harder. I go with pure, i love it, and i can feel the difference.
The most important lesson I learned from Karate-Dō Kyōshan“You can not be what you do not believe you are”
post Jun 3, 2004 - 6:56 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
On the original post, you mentioned the following.
Now, as far as I know, stop smoke is some kind of additive that you add to your car when there is too much smoke coming out of your exhaust. If this is the case and your car was already realeasing smoke, then something inside must be messed up.
If that's the case, you have to determine what color the smoke was, and then you'll find your problem.
just my $.02
post Jun 3, 2004 - 7:23 PM
Snarfer
Joined Dec 2, '03
From Virginia
You may want to look here it talks about how additives can be detrimental to the performance of your engine. I doubt you blew anything up just changing the oil, but if you are using a new oil with an additive you may want to go back to your old one and see if that fixes the problem.
post Jun 3, 2004 - 9:07 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
I tend to think that its not your oil thats causing these problems....the 5S-FE is meant to use 10w-30 so that shouldnt be an issue. First check just to make sure that no oil is leaking from either the oil pan bolt you took off or the oil cap on the valve cover. Also if you slopped any oil onto the engine in the process of changing it, it can smoke a bit and smell bad like you're runing your engine too hot.
After your sure both are tight and theres enough oil in the engine (or too much for that matter) and it still makes these obnoxious quirks, get it checked out by a reputable shop. Its not worth it to guess, and the description of the problem is so brief that i honestly dont know what else to recommend. Sometimes a simple tune up can do wonders...mine runs much smoother than it did before i got mine, so look into it if its really bad.
Besides, answers like "check your intake" or "your engine is already dead, sorry." arent really the best thing to go by anyway. wink.gif
EDIT-
Our cars tend to vibrate a little under acceleration sometimes...i get this occasionally when im accelerating onto a highway and other people have encountered the same thing. I think it has to do with the small engine under load when climbing a hill or pushing it hard in a high gear. So dont worry to much, its normal.
This post has been edited by Silver94CelicaOwner: Jun 3, 2004 - 9:14 PM
post Jun 3, 2004 - 9:33 PM
Guest_Jason_*
Actually, if the car ran on a 10w40 all its life, switching to a 10w30 can cause oil rings to swell. Thats why they recommend you to not do that, its a rare case that it would happen on a couple changes, but you never know. smile.gif
Of course, I mean, checking your intake box is only the best way to know if your oil gaskets blew rolleyes.gif rolleyes.gif , I mean, why wouldn't you check it just to make sure. rolleyes.gif And then if they already did, I don't think he wants to dish out the money to getting something like that fixed, ie: time for a swap.
post Jun 4, 2004 - 2:46 AM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
Are you saying that you may have,by accident, used stop smoke instead of oil?
post Jun 4, 2004 - 3:07 AM
macavely
Joined Nov 4, '02
QUOTE (bojangles_8686 @ Jun 3, 2004 - 2:53 PM)
Sortafamous: hmm
NunCHUCKSNinja: yep
where is the last place you got gas from.. and did you change from one oct/ to another?
post Jun 4, 2004 - 10:55 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
QUOTE (95STHATCH @ Jun 4, 2004 - 7:46 AM)
no we put that in there to help the valve seals, still used 4 quarts of oil
Lo-Fi Version Time is now: February 21st, 2025 - 11:34 AM
