> Convertible rear window switches, Electrical problems
post Jun 6, 2004 - 7:48 PM
CoolDoctorJ
Joined Nov 24, '03
From MA
Does anyone else with a convertible have the problem where the contacts inside the switches for the rear windows get charred so they don't work? I've had to clean both switches twice now, and it's getting annoying. Thanks.
Replies (1 - 8)
post Jun 6, 2004 - 7:57 PM
shid
Joined Jan 8, '04
From LA
I put both switches into one switch, and moved it below my ignition- the little switch clamps under the dash.. the one on the left was meant to be my top- but that had less than happy results. there's metal behind there and the vert switch sticks out to much- so we kept grinding and grinding and then the connect fell out. ****. still haven't fixed it.
post Jun 6, 2004 - 11:43 PM
jgreening
Joined Jan 17, '04
From Illinois
my rear windows are very sllloooowwwww. Was that what happened to yours before you found they were getting "charred" cooldoctor?
Jay
post Jun 10, 2004 - 9:07 PM
95celgt
Joined Oct 5, '03
From South TX.
my windows were moving really slow and now they just dont work i was hoping it was the switches cause it would make me mad if i needed new motors, cause no one sells the motors, Anybody know how to hook em up to another switch?
I want them to work again!!!! ARRRG!
post Jun 11, 2004 - 2:45 AM
shid
Joined Jan 8, '04
From LA
I really dont think it's the switches man.. it's the motor. It wouldn't be both switches at once.
post Jun 11, 2004 - 9:35 AM
95celgt
Joined Oct 5, '03
From South TX.
I dunno, my passenger worked then stopped and it works every now&then.
My driver side always worked, but i never used it, then i checked if it still worked and it doesnt budge confused.gif
post Jun 11, 2004 - 7:06 PM
CoolDoctorJ
Joined Nov 24, '03
From MA
I'm not sure if they actually got any slower before they stopped working... They just got kind of intermittent so you had to hit the switch like a million times before the window would go up. What's actually happening is some kind of crud (looks like electrical burns) accumulates on the contacts inside the switch. It's not a hard fix to just take the switches apart and clean the contacts, but you have to be careful not to break any of the plastic parts and it's annoying to pry up the panelling every couple months.
BTW, if you ask a Toyota dealer to do it for you they'll charge $85. It's faster and cheaper to do it yourself if it turns out this is your problem.
Hope that helped.
post Jun 14, 2004 - 9:45 PM
95celgt
Joined Oct 5, '03
From South TX.
Hey guys
I took apart the switches and man the contacts were BLACK, well i cleaned them, filed them a little and put them back together............BAM, MY WINDOWS FINALLY WORK!!!!!!! YEAAAA!.
Well im glad I didn't have to change the motors cause they are hard to come by,
But if any of you all can tell me where i can find the Convertible Top motors that would help, THNX.
post Jun 14, 2004 - 9:48 PM
shid
Joined Jan 8, '04
From LA
95celgt, I'm in the same boat as you- my passenger motor blew.. doing work on it later this summer. My window motors have also broken before.. PITA
Lo-Fi Version Time is now: December 1st, 2024 - 3:35 PM
