> engine misses
post Feb 20, 2003 - 7:30 PM
gmb69
Joined Feb 16, '03
From arkansas
i am a newby celica owner and having a problem.if this was chevrolet or ford i could fix it but this toyota is blowing my mind...i have a 95 celica gt with the 2.2 litre. in the first 3 gears it misses but i can bear down on the throttle and shift it out and it clears up. i have changed the plugs,cap,rotor and wires but it didnt help any. if anyone else has experienced this problem or had this problem fixed please lemme know. any help would be greatly appreciated. my email addy is..gmb69@msn.com......thanx
Replies (1 - 5)
post Feb 20, 2003 - 10:04 PM
west_minist
Joined Oct 27, '02
From Barbados
Is this under hard acceleration?
post Feb 22, 2003 - 8:48 AM
gmb69
Joined Feb 16, '03
From arkansas
no,it runs much better under hard acceleration..its in lower gears and lower speeds. if you just ease it around it misses bad...but if you tromp the gas pedal on down and shift it out its ok...on the highway in 5th gear its smooth and dosent miss at all. it seems to be missing the worst under 3000 rpm. above that it does ok.anything you can tell me is appreciated...mark
post Feb 22, 2003 - 1:06 PM
Milds3vn
Joined Feb 11, '03
From Phila, PA
I don't know if this is the same type of problem I had with my old Taurus but it might be the fuel pump or something in the fuel system. It ran bad pulling from a stop or sometimes idled rough and stalled at a stop. I cleaned out the dirt and dust in the mass air flow sensor with some rubbing alcohol and it helped for a short time. I still think it was my fuel pump or something in the air/fuel because under hard acceleration it was fine. I never got it sorted out cause I totaled it on thanksgiving night...DRINK AND DRIVE! It will get you a 97 Celica as a replacement...I think it was ment to be cwm13.gif
post Feb 22, 2003 - 4:12 PM
west_minist
Joined Oct 27, '02
From Barbados
Ok I see.
It more sounds like an ignition problem.
Check for bad Electrical grounds, alternator, ignition ignitor.
Also, try resetting your ECU buy tunning all lights on in the car, radio and remove the + wire from the battery for about 2 - 10mins.
Disconnect the batter and go and do somethning and come back out.
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Feb 23, 2003 - 3:42 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
good luck, I'm having the same prob with my new celi, any help on this subject would be greatly appreciated
Lo-Fi Version Time is now: November 28th, 2024 - 4:04 AM
