> E brake, car rolled
post Jun 26, 2004 - 3:11 AM
pnutcar
Joined May 13, '04
OK, so i was pulling out my waverunner today and had the car shut off, e brake on, in 1st in my 94 gt 5sp. as soon as i put the ski on the trailer, the car rolled back like a foot, scaring the crap out of me. i pulled the e brake up but it was all the way up. is there a way i can tighten it up? this is the only time it's ever done this, and i know the cable is good.
Replies (1 - 5)
post Jun 26, 2004 - 8:10 AM
gas65
Joined Nov 6, '03
From Campbellsville, Ky.
I wonder if the Celi would float since their so lite?.................Probably not. smile.gif
post Jun 26, 2004 - 3:10 PM
Junior
Joined May 5, '03
From Toronto
Remove the rear drum/rotors, depending on what you got and there is a dial on the bottom behind the shoes. That is the adjuster. PM wiht your MSN and I'll send you a PDF from the shop manual that'll tell you exactly how to do it.
post Jun 27, 2004 - 12:01 AM
94gts
Joined Aug 28, '02
From B.C. Canada
you can also line up the hole in the rotor to adjust the dial so you don't need to take it off. Drums might have the hole on the backing plate, I'm not sure.
post Jun 29, 2004 - 2:11 PM
PhillyGuy086
Joined Sep 18, '03
From Dirty Jersey
yeah they do but its a pain in the neck to adjust
post Jun 29, 2004 - 2:28 PM
LatinKraze
Joined Oct 22, '03
Try using this thread to adjust ur e-brake. Look at the second to last post my Andason. You might find this to come in handy. wink.gif
Lo-Fi Version Time is now: December 15th, 2025 - 1:27 PM
