![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
Does anyone here get clutch/flywheel chattering noises from their car at idle? My car makes a chattering noise at idle unless the clutch pedal is pressed in, and it's worrying me, because it didn't used to happen, and it gradually gets louder as time goes by.
![]() I'm running a JUN 9 lb. chromoly-steel flywheel for a AE86 GT-S, and a Clutch Masters stage one clutch kit, also designed for the AE86 GT-S. Anyone have any ideas as to what might be going on? The thought of a flywheel exploding in a FWD Celica and ending my life or taking off my legs is very scary. -------------------- New Toyota project coming soon...
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) ![]() |
i get chatter.. wone i let go of the clutch pedal to fast when in nutral.. i here it bounce hard too.. but it didn't stat it after the clutch was broken. in.. you shouldn't have to much to warry about.. aslong as you are still getting grip..
Enthusiast ![]() ![]() ![]() Joined Mar 4, '03 Currently Offline Reputation: 0 (0%) ![]() |
Coomer I used to get that with my last clutch. Best way to test it is to drive along slowly in 1st... try to listen for the chatter, and then try pulling your clutch pedal towards you with the front of your foot. If you can lift it up a bit and the chatter goes away, you need to get your pedals readjusted.
Main problem I have now with my clutch/lightened flywheel is that when the car is cold the clutch bites too hard, I have to be real careful because the pedal travel is different and it bites straight away when cold... |
![]() Enthusiast ![]() ![]() ![]() Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) ![]() |
maybe your bolts are comming loose therefore the flywheel is vibrating?
are they torqued to specs? -------------------- ![]() |
Enthusiast ![]() Joined Sep 21, '02 From SLC, UT Currently Offline Reputation: 0 (0%) ![]() |
Woah! I get that exact sound. Chattering when idling, but if I push in my clutch it goes away and it doesn't seem to be constant. Thought it was just engine chatter (I have 166,000 miles). I had my clutch replaced a year and a half ago, I wouldn't think it'd be going bad already. Sorry that doesn't solve the problem Coomer, just that I've got the same thing.
Edit: No chattering while accelerating or cruising, its strictly when idling... This post has been edited by celicaman96: Jul 13, 2004 - 12:10 AM |
Enthusiast ![]() ![]() Joined Dec 21, '03 From Lynnwood, WA Currently Offline Reputation: 0 (0%) ![]() |
Hey, commer I think these matching for ur 4A-GE is totally wrong!! How come u get some stuffs ar for older Corolla to fit ur AE111?? It should make a deep damage for ur motor, I suggest to order some suitable for ur engine is the best way. |
Nah, the AE86 stuff works fine, as long as it's all made for the AE86.
![]() -------------------- New Toyota project coming soon...
![]() Enthusiast Joined Jun 18, '04 From Lincolnshire, England Currently Offline Reputation: 0 (0%) ![]() |
I used to get this too, particularly when the engine was cold. After it came back from having a new timing belt fitted there was no more noise ![]() |
Ahh yeah, I know I need to replace mine, maybe the sound is a good indication of "Do it now!" ![]() |
Hmm...my timing belt was replaced about 10,000 miles ago.
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) ![]() |
throw out bearing ?
That's what I'm thinking now, after reading up on Club4AG. I'll test that theory out tonight when I'm off of work. -------------------- New Toyota project coming soon...
Hey Coomer, I'm curious how you're going to test the throwout bearing and what happens if in fact it's the culprit. Other than the obvious "replace it" ... Thanks!
I was told that if I just reach down and move the clutch fork while the car is at idle and the sound goes away or changes, then it's probably my throwout bearing. I'm not sure what to do if it is, but I'll post more tonight once I find out more. -------------------- New Toyota project coming soon...
If the bearing is faulty, you'll have to jack up your car, open your bellhousing and take the clutch assembly appart! Good fun for all! You can buy a new bearing real cheap ($20 AUD over here) from any decent clutch/transmission store - or even Toyota.
If you do go ahead to replace the bearing (or get a shop to do it - $$) It might be worth taking the flywheel and pressure plate and getting them balanced... If this was not done when they were put on it could definately be helping cause the chattering. |
throwout bearing SHOULD ALWAYS be replaced when you do a clutch. It sounds like its the throwout bearing to me though. Clutch chatter usually happens when you go to take off and it chatters against the flywheel. The clutch shouldnt be touching the flywheel when the car is in neutral or the clutch is pressed all the way down.
OK, I played with the clutch fork at idle yesterday and it didn't affect anything.
We did change my throwout bearing when the clutch was changed, and the pressure plate and flywheel were brand new. -------------------- New Toyota project coming soon...
wierd!
Yeah I know...I wish I could figure this out and get my hydraulic system fixed and have my car running normally again. -------------------- New Toyota project coming soon...
I was doing some more reading, and it looks like my flywheel or pressure plate may be loose...looks like my plans for the weekend just got cancelled.
Lo-Fi Version | Time is now: February 20th, 2025 - 4:53 AM |
