Is there a turn signal relay ?, help wit my front bumper turn signal |
Feb 24, 2003 - 10:36 AM |
Enthusiast Joined Dec 27, '02 From Sleep in Warren chill in clinton twp, works/school in detroit Currently Offline Reputation: 1 (100%) |
well my turn signal only works when im using my hazard or using it
its like mynzeyes' light it only lits up when he's using it i didn't cut any wires tho like he did wtf oh i just go new set of 1157's -------------------- |
Feb 24, 2003 - 11:14 AM |
Enthusiast Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
well i know theres a blinker relay, itsunder the steering wheel column,go under into the footwell and its all the way on the left, small black square with blue print on it, says toyota, 12-01, denso, made in japan , 79007 DOT
dunno bout a turn signal relay....i kno theres a turn signal fuse and a hazard fuse, those are in the fuse cluster under the driver side air vent. hope this helps -------------------- |
Mar 2, 2003 - 7:20 AM |
Enthusiast Joined Sep 5, '02 From Phoenix, AZ Currently Offline Reputation: 0 (0%) |
If the relay or fuse was out then they wouldn't even come on when he uses them. Try switching the way you put them in. I know if you get LED 1157 bulbs you have to put them in a certain way or they don't work.
Lo-Fi Version | Time is now: November 29th, 2024 - 2:56 AM |
