> how to gt ur ST celica
post Jul 27, 2004 - 4:23 AM
trdevelopment
Joined Jul 27, '04
From phoenix az
ohk guys im really serious bout gtin my celica form st 2 gt if it kan b done.i kn0 im gonna need the gt exsuast and intake manifold and head and passenger side motormount and injectors fuel rail etc but please tell me if it is even possible bkuz im really thinkin bout doing it.
Replies (1 - 19)
post Jul 27, 2004 - 4:36 AM
oOoHuY
Joined Nov 12, '03
From h town
same here
post Jul 27, 2004 - 6:20 AM
97Celica
Joined Nov 27, '02
From Derry,NH USA
Dude,that would be SUCH a friggin waste.
post Jul 27, 2004 - 6:57 AM
dstrbcelica
Joined Oct 24, '03
From fort smith, ar
former celica owner.
post Jul 27, 2004 - 9:50 AM
celicarocker
Joined Sep 25, '03
From cranston RI
it really would be a waste.... you'd need to take out just about everything under the hood, weld new motor mounts, then drop just about everything from the GT in.... unless you can get like a GT clip for real cheap, and are doing the work yourself, its really not worth it.......
post Jul 27, 2004 - 12:47 PM
forkee
Joined Nov 13, '02
From So Cal
yea for an extra 30 hp its not worth all the hassle. you might as well turbo it or swap a 3sgte in if ur gonna swap anyways.
post Jul 27, 2004 - 1:54 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
o man i have no clue what half of those words are ohk? gtin? kan? kn0? bkuz?
post Jul 27, 2004 - 2:10 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
just boost the ST. It'll be easier, more powerful, and just a bit more expensive
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Jul 27, 2004 - 3:55 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
yeh but i wanna kno if the block is the same bkuz i kan get the whole top end of the gt for bout 500 bux and i was planin on port and polishing the head bkuz i got a nos wet system that i wanna put in but am afriad ill blow sumthin up in the stok st motor. thats why i wanna make it a gt its a all around better motor if it kan b done. i was lookin at the 3sgte the motor is not that xpensive but the labor is. u have 2 put it in a fwd tranny and the only one that will run very good that i kno is fabricating the mr2 tranny.
post Jul 27, 2004 - 4:01 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
dude stick with ur st and turbo it....
to swap a gt in ur car you need :
gt engine and tranny, wiring harness,ecu, 3 motor mounts, new exhuast, axles, and prolly some other stuff i'm not thinking of right now.
Swaps are not easy, so a 3s swap I dont forsee in ur future .
Rebuild ur st motor, work the internals a little. after ur done with that, turbo it or go no2
I will return one day.
post Jul 27, 2004 - 4:04 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
do u kno if the blok is the same though
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (trdevelopment @ Jul 27, 2004 - 8:55 PM)
They're different blocks...
You'll be better off selling the ST and buying a GT. The 5SFE is not neccessarily a better motor by any means. It's just bigger. A nitrious system will work with either car in the same way, assuming you don't over-do it. A port and polish will do nothing for improved durability. It's a performance modification... as for the 3SGTE... a tranny is the least of your worries... the MR2 tranny is a direct replacement (some minor modifications may be needed). Any tranny that came on "S" series motors should hold up quite well under stock 3SGTE boost.
That being said... you should do yourself, and the rest of us here favors by typing like a normal person, instead of that "hip jive"... it's a lot easier on the eyes...
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE (trdevelopment @ Jul 27, 2004 - 4:04 PM)
no it not the same
gt s block
st a block
post Jul 27, 2004 - 4:06 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
fuk lol not kewl how do i get more power form the st b4 i put the nos in then
post Jul 27, 2004 - 4:07 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
im talkin bout engine wise not exsuast and all that other bull****
post Jul 27, 2004 - 4:09 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (trdevelopment @ Jul 27, 2004 - 9:07 PM)
Research time buddy...
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE (trdevelopment @ Jul 27, 2004 - 4:07 PM)
search around for people working 7afe I know of one guys doing a full rebuild and he's working the internals.
also search for people with turbo'ed 7a's some of them have internal work done
post Jul 27, 2004 - 5:16 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
hey how did u get ur dash lights red and how much did those xenons cost u^
post Jul 28, 2004 - 2:05 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
eye dun know bowt u gys, butt teyeping en cumplete gyberish iz toetelly awesum, u shood awl tawk lyke retyrds lyke eye dew
post Jul 28, 2004 - 2:21 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
rofl owned. Man all you need is NOS. The ST has bullet proof internals! Go to NAPA and hook up a 200 hundred shot. It should be able to handle that if not TWICE that. Then, when you're next to a dope car, lay it down. Be like, I got "NAWZ" make sure you say it like that. He'll know you want to race. Press the button, and BOOM you're gone. The other drive won't even see you. Like I said, 200 hundred shot on stock internals. 350-400 should be good for upgraded internals. Oh, change the NOS timer a few degrees and you'll be running nine's.
- Ryan
aim: rkgreen04
Lo-Fi Version Time is now: February 23rd, 2025 - 8:05 PM
