> 3 bar map sensor
post Jul 30, 2004 - 11:43 PM
DustyBurns30
Joined Jul 31, '03
From Panama City Beach, FL
today i found out the price of a 3s-gte 2 bar map sensor cost (not good). i found a 3 bar map for a decent price. would a 3 bar map sensor work on a 7a-fte setup? is there a 2 bar map that would work that isn't outragously priced?
thanks.
Replies (1 - 4)
post Jul 30, 2004 - 11:55 PM
I dont see why the 3bar would work any more or less than the 2 bar, just has a bigger range.
post Jul 31, 2004 - 1:23 AM
1bwilson
Joined Aug 30, '02
From Maryland
It will cause you to run way to much fuel. A supra 2.2bar has been tried and still doesn't work.
Member of Team 5sfTe
post Jul 31, 2004 - 12:13 PM
DustyBurns30
Joined Jul 31, '03
damn, any other alternatives?
post Jul 31, 2004 - 11:00 PM
Snarfer
Joined Dec 2, '03
From Virginia
You probably con only use one designed for that application. A 2.2 bar map sensor will have a different calibration curve then just a 2 bar, so at a given point the voltage drop of the sensor may be higher or lower then the ecm is expecting. Just as a toyota 2 bar may have a different curve then a ford 2 bar and they are not interchangable.
Lo-Fi Version Time is now: December 2nd, 2024 - 6:54 PM
