![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
what do you do when you bore out a throttle body?
how would i go about doing it? |
![]() Enthusiast ![]() ![]() Joined Jun 11, '04 From Wake Forest, NC Currently Offline Reputation: 0 (0%) ![]() |
i think you can take it to a machinist and they can do it for ya
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) ![]() |
take it to a machine shop. This is one of those things that have to be done by a professional.
ok so it take a pro....
but what is done? do they just shave the inside of my throttle body? the very begining of it(where its a circle) or the inside where it turns into the square section? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 27, '03 From Nor Cal Currently Offline Reputation: 0 (0%) ![]() |
You don't bore out the throttle body... you replace it with a larger one and bore out the intake manifold... The throttle body unbolts from intake manifold and the manifold itself can be bored out to match the larger throttle body. I'm not sure which throttle bodies fit what application... but I do know 7MG's and such have larger throttle bodies which can possibly be modified to fit... -------------------- "It's ok to be naked girl... I'm an artist!"
![]() Enthusiast ![]() ![]() ![]() Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) ![]() |
there is someone who knows which TB could fit with minor mods? cuz our intak manifold can be bored much!!!
so dos anyone know which TB could fit with just minor mods???? cuz ST intake manifold can be bord out soooooo much!!!!!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) ![]() |
the 22re is suppose to fit w/ minor work. the 5sfe has a 50mm tb and the 22re has 55mm i believe. I've been reading about this on celica.net.
This post has been edited by chucho: Aug 10, 2004 - 9:22 AM |
& i hear the intake manifold for the ST & GT are the same.
so we can use the re22 throttle body and minorly modify to fit our intake manifold....but couldn't i just bore it out on my own......i'm figuring out what to use at the moment....but then you could just finish the bore using a cylinder honing device?!
![]() Enthusiast ![]() ![]() Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) ![]() |
I'm 99.99% sure that's not the case. Perhaps the TB bolt pattern is the same, but all the 5SFE manifolds I've ever seen were a lot different than the 7AFE. |
the manifold is now doubt different but the TB connection might be the same
Enthusiast ![]() ![]() ![]() Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) ![]() |
i just want to point out that on celica.net Schmleff actuatly cut off the part of the 5sfe intake manifold where it connects to the tb and replaced it with 22re connecting peace. so im guessing that the TBs dont match up.
-------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Honestly... IMO, some of the things those guys (celica.net n/a power forum regulars) do and/or think they should do, are pointless... worthless... and backwards. Crazy mix'n match stuff... swap stock parts for stock parts... spends hundreds for a stupid mod using stock parts that can potentially cause power losses rather than gains... amougst other random cut-paste ideas. An example... Schmleff's TB upgrade... which he basically builds and welds and adaptor to fit a 22RE throttle body... FYI... if you REALLY want a good EFI intake system... ITB's (Individual throttle bodies) is the ONLY way to go. Considering Schmleff has access to a machine shop (something even I don't have immediate access to)... he can just as easily build an adaptor plate capable of mating 4AG 20V ITB's to the 5SFE and or 7AFE. Instead... he spends a lot of time custom fitting a single throttle body that has no real advantage over the stock one (the stocker is that size for a reason) which will do little for his torque band (might actually lose intake velocity which will cause torque loss)... Kinda backwards if you ask me... but whatever... the readers of that forum seem to really look up to him... ![]() Back on topic... Like mentioned above... you'll only need/want to do the throttle body upgrade if your engine is capable of utilizing it (higher compression, forced induction, aggressive cam profile, etc...) Might not even do anything on a stock motor... This post has been edited by Kwanza26: Aug 11, 2004 - 3:26 AM -------------------- "It's ok to be naked girl... I'm an artist!"
then what about a throttle body spacer, i've been hearing about those for integs and stuff but not sure what they do and such, any body know?
Okay well i'm planning on getting higher compression pistons, web-cams, and do some head work(P&P, 3 angle, etc.) so I'm going to do, or hoping to do, a TB upgrade 'cause it would help w/ the setup i'm going after. So this is important information/knowledge to me which i'll need within the next 6 months. |
Lo-Fi Version | Time is now: February 20th, 2025 - 6:20 AM |
