> BEAMS update, August 10
post Aug 10, 2004 - 11:44 PM
Outsider
From Kelowna, BC
I guess it's time for another update. I have been very busy at work trying to finish a contract(should be done this weekend) so not much has been done.
Now that the harness has been modified to fit the car it is time to go through the connectors, pin by pin. I have finally recieved a BEAMS engine wiring diagram thanks to Mario at Toysport. So many wires, so many connectors. Where to start? I choose to break the project into systems as they are drawn in my BGB wiring manual.
  • Charging
  • Starting
  • Air Conditioning
  • Cruise Control
  • ABS
  • SRS
  • Ignition
I will only work on the connectors that tie into the body harness beside the ECU and the engine bay fuse box. Any connectors that go to the ECU or anything on the engine I will not touch.
CHARGING
exact match, no changes required.
STARTING & IGNITION
One wire was missing on the BEAMS harness. Connector IJ1 was missing pin 17. Turns out this wire goes to the clutch start switch. Easiest thing to do was remove it from my old harness. I pull pin 17 from the connector and start to unwrap the old harness. I discover that it splices in about 6 inches away from the plug. Excellent I say. Problem solved. Wire has been added.
AIR CONDITIONING
This system requires looking at 2 connectors.
IM1 - goes to A/C computer.(7 wires)
A2 - goes to A/C pump. (4 wires)
The BEAMS harness A2 plug only has 3 wires. OUCH. time to trace things out. looking at the IM1 connector, it is also missing 1 wire. Easiest solution? I once again pull the missing wire from my old harness. Should be a perfect fit I am thinking. Same connectors, in the same locations on both cars. Ya right. The wire turns out to be about 6 inches short and gets spliced. Wire added.
Well, that's it so far. I hate not having time to work on the car and have decided that Sunday is car day. If I do not set aside time for the car, it will never get done.
This post has been edited by Outsider: Aug 19, 2004 - 10:20 PM
1994 GT-S (BEAMS) swap complete
Replies (1 - 13)
post Aug 10, 2004 - 11:48 PM
hioctane
Joined Nov 26, '02
this thread is worthless without pics/ videos. useless !!!
This post has been edited by hioctane: Aug 10, 2004 - 11:49 PM
post Aug 11, 2004 - 12:01 AM
Ale_lock
From New York City, NY
QUOTE (hioctane @ Aug 11, 2004 - 12:48 AM)
It isn't completely useless but those would be real helpful to better understand what exactly you are talking about.
This post has been edited by Meonspeed: Aug 11, 2004 - 12:01 AM
post Aug 11, 2004 - 12:19 AM
ghostdog
From ny to philly
I for one think its pretty cool that hes taking the time to give us an update when he is obviously busy with work and other things. sure some pictures would be nice, but considering this is one of the only beams 3sge swap being attempted to date any information no matter how small or seemingly inconsequential could be helpful to future swappers. thanks and good luck outsider.
post Aug 11, 2004 - 7:22 PM
RedSunCelica
From San Diego CA
QUOTE (gh0st_d0g @ Aug 10, 2004 - 10:19 PM)
keep up the great work and keep us posted
post Aug 11, 2004 - 7:35 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (hioctane @ Aug 11, 2004 - 4:48 AM)
Heheh... you probably think it's worthless only cause you don't understand it... ;]
and he does take a lot of pictures btw...
Outsider: Mad props to you for being the guy with the biggest balls and enough know-how to attempt this mind numbing swap. Hope you keep at it and finish up eventually... ;]
post Aug 11, 2004 - 7:38 PM
Awesome! Glad to hear that you're continuing to make good progress. smile.gif
post Aug 11, 2004 - 9:29 PM
Junior
Joined May 5, '03
From Toronto
I'm gonna have to keep close touch with you. I'm working of getting a blacktop. It is hard to get it with everything
post Aug 11, 2004 - 10:31 PM
i enjoyed reading this thread.... its nice to see how the beams and the 3s differ in wiring.
it would be great if u post any info that you learn about the interrior plugs (like IJ1) in your reasearch. id like to know what every pin on all those connectors is used for and why.
post Aug 11, 2004 - 11:54 PM
Outsider
From Kelowna, BC
Thanks guys.user posted image
When I am finished I will be setting up a website. I have had a hard time tracking down wiring information and intend to set up a wiring archive with all plugs listed and what each wire does.
This post has been edited by Outsider: Oct 5, 2005 - 1:36 PM
post Aug 12, 2004 - 11:38 PM
FallenHero
Joined Dec 26, '02
From Alabama
Your work is Great man, keep it up. I can't wait to see how the beams performes.
post Jan 26, 2005 - 2:21 PM
chucho
Joined Mar 23, '03
From New Orleans
ne updates??
post Jan 26, 2005 - 3:41 PM
dstrbcelica
Joined Oct 24, '03
From fort smith, ar
keep it up mang.
-dstrb
former celica owner.
post Jan 26, 2005 - 3:48 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
lol, everything sumed up...you're only 6" short in every direction tongue.gif
i'll give you an early Congrats, cuz i know you're gonna pull this off smile.gif
Lo-Fi Version Time is now: January 17th, 2025 - 6:37 PM
