> Soldering in LED's, resistor ?
post Aug 15, 2004 - 8:06 PM
CelicaB
Joined Sep 24, '03
From Medina, OH
i did a search but if you want to change climate control light colors ( i know it not REALLY climate control) why do you need resistors? (im electrical stupid) why cant you un-solder the green ones and solder in the blue ones it would make everything soo much simpler than all this talk about running resistors and what not soooo if someone could elaborate on this a lil for me it would be greatly appreciated!
Replies (1 - 7)
post Aug 15, 2004 - 8:19 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
you can solder the indicator leds directly to the board. however the leds to light up the unit would need resistors cause you cant screw them in like the 3 bulbs you are replacing.
here is what to do for the leds that need resistors.
you need to find a power source that turns on with ur lights.
run ur positive from there, add a 220 ohm resistor to the wire then attach the led, now find a negative source and attach it to the negative led strip. you'll find that ur leds will shine really brite. then you can postition them anywhere in the unit you'll have to do this atleast three or four times but you cna use the same source for power.
people will say you dont need resistors... trust me I have done it with and with out resistors. with resistors looks the best.
let me know if you need any help
later
DEF
I will return one day.
post Aug 15, 2004 - 9:05 PM
CelicaB
Joined Sep 24, '03
From Medina, OH
Ohh so the resistors acctually (sp?) will make the LED's brighter by using an outside 12volt source? hmm makes sence but since im going with different color buttons ill try w/o them first i can always add them later i guess i really wanted to make sure they would light up and not fry anything important lol thanks for you help
post Aug 15, 2004 - 9:22 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE (CelicaB @ Aug 15, 2004 - 9:05 PM)
you dont need resistors for the leds you replace on the board.
but you will need them when you replace the bulbs with leds. cause you cant screw the leds into the board like the bulbs.
thats where the new power source comes in
good luck
post Aug 15, 2004 - 11:02 PM
CelicaB
Joined Sep 24, '03
From Medina, OH
ohh ok i see well i just wanted to replace the LED's i already painted the bulbs - thats where i was getting comfused i understand now thanks for your help!
post Aug 15, 2004 - 11:07 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE (CelicaB @ Aug 15, 2004 - 11:02 PM)
no prob take some pics when ur done
post Aug 15, 2004 - 11:19 PM
CelicaB
Joined Sep 24, '03
From Medina, OH
will do and i still have to figure out how to work my digi cam to post pics of my car too and thanks again
post Aug 18, 2004 - 3:41 PM
kgr-gts
Joined May 20, '04
From Saskatoon, SK, Canada
ok, so if I only want to replace the A/C light with a blue LED, I don't have to worry about adding a resistor, correct?
The resistors are just for the 3 bulbs that provide the illumination?
I'm going to go searching through the forums now, but I might as well ask the question in this post if someone's going to reply to it anyway:
What model/part# of blue LEDs have people used to replace the A/C light (and other smaller lights like it)?
Thanks,
Kevin
Lo-Fi Version Time is now: December 12th, 2024 - 11:08 AM
