> hyper ground system, anybody have these
post Aug 22, 2004 - 10:55 PM
negativexero
Joined Jul 20, '04
From colorado
i was wonderin if anyone else had the hyper ground system wires and if they really add some horses from just grounding? im gonna put these on in a couple weeks in auto shop
Replies (1 - 3)
post Aug 22, 2004 - 11:02 PM
shid
Joined Jan 8, '04
From LA
If it's just a grounding kit, than you won't get any hp gains. If it's a voltage regulator, you will get gains.
I have a home made grounding kit; 4 guage wire replacing the stock chassis grounds ::shrugs:: clearer sound system, better electrical power throughout the car.
I don't DARE say it does anything for performance tho.
A hyper voltage system will add some pep tho- and a LOT of pep on a turbo'd car.
post Aug 24, 2004 - 4:20 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
shid, how did you make this? just replace the stock ground wires with 4 gauge wire? what about the battery terminal connector, like you see on a lot of aftermarket grounding kits?
post Aug 24, 2004 - 9:47 AM
shid
Joined Jan 8, '04
From LA
You can just buy that seperate; make your own or whatever. It's not like the voltage kit; which has specific parts. The materials that go into the hyper voltage kits can be found at any hardware store.
Lo-Fi Version Time is now: November 28th, 2024 - 2:57 AM
