> coilovers, seeking and poping noises
post Aug 23, 2004 - 10:35 PM
Fabulous
Joined Feb 29, '04
From California, US
I have installed full set of height adjustable coilovers on my 95 Celica. Now the front two struts are making sqeeking and poping noises. Is this a strut cap barring problem or something else? Help advice please rolleyes.gif
Fabulous
Replies (1 - 5)
post Aug 23, 2004 - 10:53 PM
VietCelicaGt
Joined Aug 13, '03
i always thought when u use coilcovers it mess up ur car. but what do i know...soo here a link http://www.z31.com/coilover.shtml
hope it help...
post Aug 24, 2004 - 12:01 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
This is what you need to get.
Description :
Have Ground Control coilovers? Sick of them popping every time you turn the wheel? EvilSpeed can help. The popping sound you are hearing is a result of the spring binding. Anytime the spring compresses the spring ends must rotate with respect to each other. Any time the wheel is turned the spring must move relative to the upper spring perch. It doesn't! This is supposed to be accomplished by using the factory upper bearing and the perche supplied by Ground Control but many people (including myself) have found that this method is unsatisfactory. The spring doesn't turn as it should and instead binds and pops. Think of twisting a spring and letting go. This is exactly whats happening in your front suspension every time you hear the infamous 'popping'. By install specially sized needle bearings between the spring perches and the spring the spring is allowed to float freely and cannot bind. This eliminates the popping sound and restores the ride quality you expect. I highly recommend installing the bearing kit in both the front and the rear of the car to allow the springs full range of motion.
You can get them at EvilSpeed.com
Just go to the Products page and select " SSTOP THE GC POP"
good luck.
post Sep 1, 2004 - 12:32 AM
Fabulous
Joined Feb 29, '04
From California, US
post Sep 1, 2004 - 10:35 AM
sphinx
Joined Apr 10, '03
fo shizzle
post Sep 1, 2004 - 11:39 AM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
Actually I don't think you need to buy that. Have you lubed up that bearing pretty good and made sure everything was aligned properly?
I don't know if you want to spend that kind of money on something that you could just fab your self or make yourself? You might want to twisty tie that aluminum had onto the spring also. Here's pic.s
I used a protector from my friends Aerospeed Coilovers (i think) when I had my GC's and just lubed that protector and the bearing, made sure everything was aligned and locked into the right position and the noises went away.
Lo-Fi Version Time is now: November 25th, 2024 - 12:58 PM
