> Gen 5 indicators on 94-95 bumper, How to get them to fit
post Aug 25, 2004 - 4:55 PM
djrob90
Joined Aug 24, '04
From London
I've seen on several posts people who have fitted gen 5 front indicators to 94-95 bumpers even though they're a bit smaller. I've bought some, but cant seem to screw them into my bumper, anyone care to mention how they done theirs, someone suggested glueing to me but if my bulb goes, what a pain......
Replies (1 - 7)
post Aug 25, 2004 - 5:05 PM
Rjb23
Joined Feb 8, '04
From KY
You have to redrill the hole for the screw at an angle, and cut the bracket off of your old turns and epoxy them onto the new turns.
post Aug 25, 2004 - 5:37 PM
LatinKraze
Joined Oct 22, '03
I redrilled the new hole. I pulled the tab that holds the screw to the bumper and relocated it, instead of gluing the old bracket to the new. I removed the metal tab and installed it back wards. By installing back wards it moved the hole (where the screw goes) closer to the inside of bumper, therefore aligning the new drilled hole to the metal tab with out cutting or gluing brackets.
post Aug 25, 2004 - 5:41 PM
Rjb23
Joined Feb 8, '04
From KY
You still need to cut off the new bracket, and glue the old bracket on to the new turn, if you don't nothing will hold in the new turn on the inside, toward the middle of the car.
post Aug 25, 2004 - 5:42 PM
LatinKraze
Joined Oct 22, '03
Dont need too. The moved metal tab pushed the original brackets into the bumper.
post Aug 25, 2004 - 6:14 PM
Rjb23
Joined Feb 8, '04
From KY
I see what you are saying, its been a while since I did mine, and I was thinking that the 93 bracket is not wide enough for the slots on the bumper.
post Aug 25, 2004 - 6:37 PM
LatinKraze
Joined Oct 22, '03
I was too lazy to cut the brackets. I got lucky and found a way around it.
post Aug 27, 2004 - 10:08 AM
LatinKraze
Joined Oct 22, '03
Pic 1 = New Hole
Pic 2 = Shows Stock brackets on 90-93 turn signal
Pic 3 = Metal Tab (original position)
Pic 4 = Metal Tab Removed
Pic 5 = Metal Tab placed to line up with screw
By moving the tab over, it caused the new turn signal to properly fit to the slots where the original turn signal went.
Lo-Fi Version Time is now: November 24th, 2024 - 3:03 AM
