Oil weights, what do you use? |
Sep 6, 2004 - 10:40 PM |
Enthusiast Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) |
Like the title, what do you use? I went from 10w-30, up to a 15w-50 for my last one, and it made me sick when i started it up and started driving it, so laggy, i hated it. Next change will be right to what the oil cap says on it, 5W-30. And of course, synthetic, i don't put normal mortor oil or mix's in my car.
-------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
Sep 6, 2004 - 11:32 PM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
5w30 castrol syntec
Sep 7, 2004 - 1:30 AM |
Enthusiast Joined Apr 23, '04 From WA Currently Offline Reputation: 3 (100%) |
I have high mileage (180,000)
and every body is telling me to switch from synthetic to regular good idea? |
Sep 7, 2004 - 9:03 AM |
15w50 Mobil 1 synthetic.
I'll most likely drop down to 10w next change, 15 seems a lil excessive. This post has been edited by Supersprynt: Sep 7, 2004 - 9:07 AM -------------------- |
Sep 7, 2004 - 9:04 AM |
usually you switch from regular to synthetic. IDK why people are telling u to go to regular, stick with the synthetic. -------------------- |
Sep 7, 2004 - 11:20 AM |
Enthusiast Joined May 23, '04 From Meridian, MS Currently Offline Reputation: 2 (100%) |
i thought it has to do with your location as to what grade is best for your car, i live in the south (MS), and everyone is telling me to def. not use synthetic, cuz it will tear up your engine, i don't understand this and think they are all hicks and don't know hat they are talking about, my dad has always used 10w 30, but my car will be used for racing and have no idea what oil to use, and how often to i change it, i know its normally evry 3000 or 3 months, but i have heard to change it about every 1500 if it is being raced, and as far as when you first put in a motor, how often do you change it, it is a rebuilt motor, someone here told me to just wait till I finish breaking it in (going easy on it till 2500 miles) and then change it fo the first time, but a friend said he changed his like every 500 to 1000 miles until it was broke in with his new engine, he says if you don't it will tear up your engine faster
thanks for any help with the matter This post has been edited by celicaracer18: Sep 7, 2004 - 11:21 AM -------------------- |
Sep 7, 2004 - 11:26 AM |
I use Mobil Drive-Clean 10W40 in my car. I may switch to Mobil1 full synthetic soon, but I'm not sure...my engine, like most AE101 4A-GEs, burns a small amount of oil(like a fifth of a quart every 800-1,000 miles), and I'm not sure if synthetic would make that worse because it can penetrate where regular oil can't.
Sep 7, 2004 - 12:03 PM |
castrol syntec 10W 40 I think one of my seals in the turbo is toss i'm getting a little oil in the air filter tube
Sep 7, 2004 - 1:28 PM |
temperature effects which oil weight you should use. hotter ambient temps should use a thicker oil, as it will not breakdown as fast, as colder temps use a thinner oil. Synthetic/regular I dont see as "tearing up ur motor" that doesnt make any sense. Synthetic oil is a more durable oil, doesnt break down as quickly as natural. -------------------- |
Sep 7, 2004 - 1:46 PM |
Maybe they tell you not to use it because maybe they used it and it caused leaks in their engines. Synthetic oil will be able to make it through some leaks that regular oil can't make it through, so maybe that's why the people you know tell you not to use synthetic oil. -------------------- New Toyota project coming soon...
Sep 7, 2004 - 1:51 PM |
If ne one is interested, heres something I read from the Alltrac forum, its long, and gets complex, but its a good read.
Synthetic Oil Myth -------------------- |
Sep 7, 2004 - 3:08 PM |
Enthusiast Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) |
ah i just uhhh kinda mix um around well, when i had my celi. it burnt oil a lot anyways. i usually mixed some 20w 50 in there a a little straight 30 weight. but it was mostly castrol 10w 30.
-------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Sep 7, 2004 - 4:48 PM |
Enthusiast Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) |
Straight up Mobile1 fully synthetic 10w30, with mobile one specially designed synthetic filter. Costs 40 bucks a change but its worth it.
Sep 7, 2004 - 5:11 PM |
Enthusiast Joined Jun 11, '04 From Wake Forest, NC Currently Offline Reputation: 0 (0%) |
10w30 Synthetic the Advanced Auto Parts brand, and then use two of those Engine Restorer bottles so it averages out to alittle less than how much it cost to but just Synthetic put in, and those Orange Filters, forget the brand...
but i change my own oil so it cost alittle over $20 bucks to buy all the oil and i change it ever 2500-3000miles (drive my truck hard, needs it changed that much ).. |
Sep 7, 2004 - 6:10 PM |
so what exactly should i use in my 3sgte if i live in a very humid area. and how often should i change it
Sep 10, 2004 - 7:32 PM |
Enthusiast Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
I use VR-1 Racing 20W-50. Works great and lasts long...the engine burns around a quart every 3-4 days.
Sep 10, 2004 - 7:48 PM |
toyota recomends 10w30 for a 3sgte.
Lo-Fi Version | Time is now: November 25th, 2024 - 2:25 AM |
