> Fiberglass trunk, The whole think
post Sep 12, 2004 - 6:10 PM
Exile04
Joined Aug 20, '03
From Seattle, Washington
So i was thinking that i want to fiberglass my whole trunk but keep it almost like it is now but just raise the bottom alittle so i cna fit my sub in the spare tire hole. u guys think thats a good idea or not? im have been going back and fourth with it and im not sure. The reason i say the whole think is because the plastic sides are crackign some what so i thought why not redo the whole thing. I would paint the sides that would be painted black and put plexglass around the sub with black underneath.
PS i was thinking of using chicken wire so that if it turns out bad i can just take it out and try something differnt. What do yall think?? i dont knwo if its good idea or not
Replies (1 - 15)
post Sep 12, 2004 - 6:52 PM
Andason
Joined Jun 26, '03
From Wisconsin
youd be better off using wood
i am awesome
post Sep 12, 2004 - 7:57 PM
Exile04
Joined Aug 20, '03
but wood is so heavy..and cost more
post Sep 12, 2004 - 10:28 PM
Sev408
Joined Dec 4, '03
if you plan on using your hatch at all i suggest just carpeting the fiberglass, dont paint it. the paint wont last long at all with normal use.
user posted image hows it taste motha f*cka
post Sep 13, 2004 - 6:53 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
QUOTE (Sev408 @ Sep 12, 2004 - 8:28 PM)
Im no expert, but I would say that if you used carpet you might as well use MDF instead. Its cheaper, easier to work with, and would probably allow you to fasten the carpet easier. wink.gif
post Sep 13, 2004 - 6:59 PM
Why not just fix those plastic panels and then just fiberglass a sub enclosure in the spare tire well? It wouldn't be that hard to to. smile.gif
post Sep 13, 2004 - 7:46 PM
Exile04
Joined Aug 20, '03
cuz what would i use to fix the plastic?
2nd i was think plexiglass top with fiberglass on the spare wheel bottom and paint it black so would that work but the the 2 together?
And what would i do about the rest of hte trunk carpet it?
post Sep 13, 2004 - 11:58 PM
Andason
Joined Jun 26, '03
From Wisconsin
wood would be a LOT cheaper and easier then FG ive dealt with FG and anyone who has will agree
i am awesome
post Sep 14, 2004 - 3:20 AM
QUOTE (Andason @ Sep 13, 2004 - 9:58 PM)
True, it's cheaper and easier to make basic boxy shapes out of, but making complex curves like the stock plastic panels isn't exactly easy with MDF. wink.gif
post Sep 14, 2004 - 4:44 AM
raz128
Joined Oct 29, '03
From Gosport, Hampshire, UK
MDF is tooo heavy...
I'm gonna be re-doing my boot-build in the next few weeks using Plexiglass and perspex..... i'll hopefully get some work-in-progress pics and final pics once it's all done smile.gif
post Sep 15, 2004 - 4:27 AM
creis
Joined Jan 10, '04
From Shoreline, WA
chicken wire sux, use any kinda cloth its much better to work with, and the resin wont drip though. just get wood doweling to hold the cloth where you wont.
but yeah mdf is HEAVY. fiberglass is the best choice, plus it gives much more profetional results.
post Sep 16, 2004 - 9:40 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
Fleece or felt are the fabric of choice. The soak up a lot of resin and make a pretty sturdy panel. Add a layer or two of fiberglass cloth to the backside and you'll be good to go.
post Sep 16, 2004 - 11:56 PM
Exile04
Joined Aug 20, '03
ok i need ideas now... i think i want to keep a spare tire in my car so i need to find a way to keep it in there but not take up to much room. i was thinking of useing my stock rim 15inch.
i dont know i need some ideas to mack it look good
post Sep 19, 2004 - 12:21 AM
Exile04
Joined Aug 20, '03
ok im goin to give AAA a call and have them tow me if i need it.
im goign to fiberglass the bottom and plexiglass the top then stick my amp inside and invert my sub so it sticking out the top and make everything flesk with the trunk base. think that will look good
post Oct 1, 2004 - 1:59 PM
boshuda
Joined Oct 1, '04
From Upstate New York
I saw a how-to/web article years ago where somebody did this to some car, and they used heavy duty aluminum foil to coat the trunk with, then fiberglassed on that to get a perfect mold of the trunk. Then they built their new trunk on top of that mold. I have no idea where I saw that, I think someone had done it to a Supra, but I'm not sure anymore.
post Oct 1, 2004 - 10:52 PM
creis
Joined Jan 10, '04
From Shoreline, WA
To make my mold of the driver side trunk I used clear plastic wrap (3 layers I think) and it worked perfect. just laid the fiberglass right over it and pulled it out when it was dry.
Lo-Fi Version Time is now: December 4th, 2024 - 5:58 PM
