> redoing the interior, how to strip the pain
post Sep 20, 2004 - 7:06 PM
jbnery6465
Joined Sep 14, '04
From SaN DiegO, CaLi
i did my interior back in hs days and want to redo them. i painted the console and the vents etc...but they're starting to crack and bubble...whats the best and easiest way to take the paint of without damaging the parts...any suggestions...
Replies (1 - 6)
post Sep 20, 2004 - 7:18 PM
sand it down with like 160 grit then like 800 grit
post Sep 20, 2004 - 7:48 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
Yea you can't take off the paint. You need to sand, prep and paint over what you've already got.
post Sep 22, 2004 - 3:49 PM
jbnery6465
Joined Sep 14, '04
yeah...i should prolly just sand it, prime it, then repaint it...now what about clearcoat...i did it before and it turned out okay...do i apply the clearcoat when the paint is wet or dry...
post Sep 24, 2004 - 3:18 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
You should allow it to flash off. That means you should wait for the clear coat to start to dry, but not wait until it dries when you put on another coat. Flashing off means that the flash (or shinyness) starts to kick off. That's when you should put another coat. The reason is if you keep putting more and more coats over wet paint, it will never dry and you'll have a big glob of clear on the interior. The reason you don't wait for it to dry is because most clears lose the ability to chemically bond with another coat once it's dry. But if you do decide to wait until it dry's before adding more coats, wetsand each time before the next coat. Wet-sanding opens up the chemical bonding stuff again.
post Sep 25, 2004 - 7:02 PM
jbnery6465
Joined Sep 14, '04
QUOTE (flipside97LTD @ Sep 24, 2004 - 8:18 PM)
does this apply to when i put the first coat of clear on the pieces after i color them?
post Sep 27, 2004 - 7:44 AM
shadycrew31
Joined Jun 29, '03
From canoga park , ca
yes after you paint, you clear. but make sure its not to dry or to wet if you mess up just stirp and try again..but umm are you coming up for the socal meet in october? casue if you are i think we all can help you there. unless you wanted to do it before hand?? i dunno pm me and i can help you more. i did 3 or 4 interiors so far but im no whizz.
Lo-Fi Version Time is now: February 22nd, 2025 - 10:05 PM
