Sep 21, 2004 - 5:09 AM
![]() Enthusiast ![]() ![]() Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) |
What bolts are required to be removed to take off the stock front bar? I know its noob but hey.. =P
Sep 21, 2004 - 7:04 AM
Enthusiast ![]() ![]() Joined Nov 29, '03 From Hampton, VA Currently Offline Reputation: 0 (0%) |
What's the front bar?? Do you mean the aluminum reinforcement behind the bumper? If so, I wouldn't take that off unless you want to become a sardine in an accident.
Sep 22, 2004 - 9:55 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
how do you make it not show in the invader dront. how would you even go about fighting an intercooler in there with the bar? i had to take mine out to fit my invader on. i had no other way around it.
Sep 22, 2004 - 10:00 AM
Enthusiast ![]() Joined May 3, '04 From Alhambra 62001 Currently Offline Reputation: 0 (0%) |
From what I have seen you need to modify the front bar to make it all fit. But dont just take it off, if you get into a small accident you deploy (sp?) your air bags, even if you rearend someone around 5mph. Some insurence companys also might not cover you if you remove it. Its put on for your protection. If you hit someone at say 60mph.......well you should order your plot of ground now, and pick a nice box to be put in the ground in. J- |
Sep 22, 2004 - 6:31 PM
Enthusiast ![]() Joined Sep 14, '04 From SaN DiegO, CaLi Currently Offline Reputation: 1 (100%) |
dont ever remove that reinforcement bar...thats crazy!! if your thinking of putting a fmic...just trim off any excess fiberglass from the inside of the front if you can...if not...try going top mount or something and jus get a hood scoop...lol.but i've seen it done before...its doable.
Sep 22, 2004 - 6:41 PM
i have the invader front WITH that bar......just grab a sander and start sanding the back of the bumper around the parts were the bar hits it...eventually you will be able to slide it on WITH the bar......then you grab some black paint and spray the bar so it blends in with the rest of the car
Sep 22, 2004 - 11:03 PM
and while your sanding your kit, cut the corners off the ends of the reinforcement bar with an airsaw. it still protects you but isn't as in the way. Then paint the bar black and it's gone.
Sep 23, 2004 - 3:30 AM
lol no i meant the stock front kit, the painted part.
Sep 23, 2004 - 9:44 AM
what stock front kit? if its stock why wouldn't it fit?!?!?!?! but you can't cut that bar! thats very very illegal and you won't pass anything like that
Sep 23, 2004 - 10:36 AM
Enthusiast ![]() ![]() ![]() Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) |
are you talking about the bumper cover?
-------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Sep 24, 2004 - 9:00 AM
yeah im talking about just the front bumper cover, the painted stuff
| Lo-Fi Version | Time is now: April 16th, 2026 - 1:32 AM |
