> Clutch adjustment, where to find it???????
post Sep 27, 2004 - 7:13 PM
6GGT
Joined May 24, '04
From Pittsfield Mass
I need to adjust my clutch but i cant find where to do it.....does n e one know where i can adjust my clutch?????
Replies (1 - 1)
post Sep 27, 2004 - 7:36 PM
you adjust the clutch right at the pedal.
look under there and find a brass thread rod that goes through the fire wall and connects to the pedal. turning the rod will change the engagement point of the clutch. once you have found the right spot, you will need to adjust the clutch pedal freeplay. do this by turing a round sensor type thing right at the top of the pedal, make sure you unplug the wiring that goes to that sensor before you start turning it.
Lo-Fi Version Time is now: December 2nd, 2024 - 4:31 PM
