![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
OK after about 10 min....3 15amp fuses and some playing
if you hook the RED wire at the MIRROR to a power source then a GROUND to the BLACK wire at the MIRROR you get it to move DOWN then a GROUND to the BROWN wire at the MIRROR you it to move RIGHT thats as much info as i have now.... BUT that is not goin through the "relay/control switch" that is just wires to wires |
on the mirror the two outside wires on eachside *all the wires EXCEPT the brown, red, and black* control the retractable motor......you can put positive on the left and ground on the right and it goes one way...switch the wires and it goes the other way....same for both sides
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) ![]() |
thats awesome.. I was gonna mess around with mine today but ended up not having time.. did you get urs to work fully??>?
-------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
Don't you still need the relay box so that the box can sense motor resistance and stop applying power to the motors?
neverstop-no i havn't gotten them to work cause i havn't gotten it compatable with the relay box that you control it with
Coomer-yes you still need it i'm still trying to figure out how to do it |
wait.... relay box?? is there something I'm missing?
I have the mirrors and the little controller thing you pop into your door panel to replace the stock one... is there something else? -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
no the controller thing for the door IS the relay
okay cool
![]() edit: hurry up! LOL j/k but I do want mine to work also and wanna see if you figure it out. also want suggestions on how to make it work with the ignition.. like you turn on the car and they fold out and turn off the car and they fold in This post has been edited by NEVERSTOP: Oct 12, 2004 - 9:25 PM -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
yea well i'm on GMU's dive team, and that is a ton of time i have to do that.....and i'm getting really pissed about it so i'm trying to quite maybe so i'll have more time.....and my pop's is goin to help me work on them when i have free time so i'll let you know NEVER when i get the time.........and when i said the two wires on each end of the plug that is onthee actual mirror do the retracting i believe one side's wires are the button and the other sides mirrors are the ignition you can try and find out which side is which
ne updates on this???
I messed around with mine a little today.. I got most of the functions to work on the drivers side mirror.. I just cant seem to make it go down ![]() The mirrors moving is AWESOME!!!!!!!!! I cant wait to have it all hooked up. Playr... some of my pins are different than yours.. Im hopefully gonna try and work on it some more tomorrow and I'll make a cool little diagram like yours to compare. edit: is it possible that toyota made different versions of the folding mirrors?? the back of my relay box has a total of 10 pins in it... 6 across the top row and then two section on the lower row of two each This post has been edited by NEVERSTOP: Nov 1, 2004 - 12:58 AM -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) ![]() |
![]() Heres what I got Do you guys have this piece? ![]() -Ti |
My relay has even more:
The Actual control unit, the piece on the door that you push that makes the mirrors move
Left mirror - drivers mirror USDM/Passenger Mirror JDM
Right mirror - passenger's side USDM/Driver's Side JDM
Now each of these wires can be matched to another except Blue/Yellow in the relay itself. This could be ground though. Let me know guys. -Ti This post has been edited by turboinduction: Nov 1, 2004 - 12:19 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) ![]() |
blue/yellow, sounds like a remote control wire...that would be amazing...
j/k so what all of you are sying is that each set of mirrors is different...great -------------------- ![]() |
ok we didn't get that relay box.....we only have the control unit that goes in the door......
and the wires are the same for all of them but why do we need the USDM mirrors----you got that wrong those are only 3 wire you posted the JDM mirror wires |
didn't understand you here? Neverstop is missing the relay too?, and I posted all of the JDM stuff.... No USDM in there. Also found this, for a 5th, but it might help http://www.radcastro.com/Projects/Project+ST2GT4/580.aspx -Ti EDIT: ohhhh, i see what you meant.... No, those ARE JDM specs i gave.... I said USDM driver because I didn't wanna confuse people if I said Driver's mirror (meaning left) and they thought right because of the JDM. This post has been edited by turboinduction: Nov 1, 2004 - 4:41 PM |
lol there ya go
![]() yea i don't have that cpu relay box i wanna find a way to get around it since its not really easy to find |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
My set of mirrors are on the way, with control & relay. I'll try to add what I can when I get them. I got the 6th gens as well. I also want to find out how to hook them up so they open when starting the car, and close when you shut off the car.
Guess I'm a 6 g c p i m p haha Later, DEF -------------------- ![]() I will return one day. |
![]() -Ti |
I just got the set that was on ebay. I am kinda excited but I think I am having second thoughts.
I might want to sell these instead of installing them. No extra charge, just what I paid. Any interest, PM me. -------------------- |
batman.. I might be interested if it has all the parts.. could always use an extra set
his are missing the relay, I was biding on those but backed out when I found out I needed the relay.
I emailed the guy I outbid and it looks like he will take them. Unless anyone here wants them. Let me know
NOTICE TO ALL:
I suggest that unless you are very good at electronics, DO NOT bid on Power Folding mirrors until one of the 5 of us figure out if they will work. 1. Has to figure out wiring 2. Has to figure out movement or glass transfer so I can see out of them Of course, if you want to buy them go ahead.... but better safe than sorry. Any updates guys? -Ti |
yo if you have that relay box i want it NOW....lol
but i need that since i gues you have to have it 6gc PIMPS |
TI, is there a part # on that relay box ? That would be the key to everything...
duh@! lol why didnt I think of that ![]() If you can find a part number TI put it up here and I'll try and locate it ASAP... think I will call jeff at toyota world today also and see what he can come up with.
Im gonna try and do that today if I can get away from work long enuf to rip the extra set off the 94... think it should be no problem at all -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
yea if i can get a part numer i will love you forever once i have that its a matter of a few hours till we can hook them up
okay... think where in luck with the mirror swap.. I opened up my pass side JDM and USDM.. you basially have to use a flat screwdriver and pop off the glass... stick the screwdriver on the underside of the mirror (bottom) and pop it off. You need to remove 3 screws and the motor assembly for the mirror will come out.. there are 3 wires that have to be cut. luckily there red, black and brown on both JDM and USDM.. so hopefully there the same function for both. I will finish putting the USDM mirror in the JDM housing in a few mins and let you guys know if it can move still like the USDM one.
Here are a few pics of the USDM one: ![]() ![]() ![]() -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Enthusiast ![]() ![]() Joined Dec 24, '02 From Wirral, UK Currently Offline Reputation: 0 (0%) ![]() |
Looks like us BRITS will have to help you guys out YET AGAIN !!!!!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() http://www.celica-club.co.uk/cgibin/phpbb2...pic.php?t=20810 |
This is nice
![]() edit : the pic ![]() This post has been edited by Batman722: Nov 2, 2004 - 3:39 PM -------------------- |
KICKA$$ ben once agian you have been nothing but helpful
![]() just wish I had time at the moment to read the whole howto as for the mirror swap... WORKED PERFECT! no probs at all and even got to retain the JDM glass! and we all know how important that is ![]() Like 5 extra HP just in the glass ![]() The only prob I had is when I spliced together the wires I tried to use posilocks.. which where too big to fit into the allowed space for the wires.. you'll see what I mean when you open them up yourselfs.. TO get around this I just used electircal tape and then heat shrinked over it... worked perfect... its nice to be able to see outta my pass mirror agian ![]() Gonna do the drivers either later tonight or tomorrow - dont expect ne probs with it but will post results regardless -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
since I love you all
I'm not sure of the part number but heres whats written on top. I assume it is, but no flaming if its not. Toyota Mirror Control 12V 87989- [20030] The 20030 is raised up Hope that helps -Ti But from that write up it looks like you dont need the relay as your stock one will do. YEAH US! |
hmmmmmm site bookmarked for when i get the celi back and running
wait maybe not
Playr heres your pic ![]() just like mine........ We have a Pink (Light Red) wire in the upper right. They have a Red/Yellow and a Blue/White wire.... how do we overcome this? -Ti This post has been edited by turboinduction: Nov 2, 2004 - 4:44 PM |
once again I can't take the credit.. one of the UK club members sorted it out.. all kudos goes to him.. I just like to share information out.
I just looked..... I have a Red/Yellow and a Blue/White wire on my relay though...
hmmm i could have gotten different reactions on my set because i didn't have the relay(the box) so that could have made things different i say go with that site cause the box changes alot
I would go with the site
BUT! That site has 9 wires in the control unit Mine only has 8 Instead of the Red/Yellow and Blue/White - I have a Pink -Ti |
I will have my mirrors in about a week or so. A few days after that I will have them hooked up and working properly. Honestly, I don't really care if they can't be adjusted with the switch, just as long as they fold in and out
![]() I will try to wire them without the relay like on that site and have them work 100% normally. If not I will order the relay. I have wired plenty of things before and I will be able to figure these out when I get them. NEVER, if you are able to get the stock relay let me know. -------------------- |
I emailed the writer of that how-to. If he emails me back i'll let you guys know.
-Ti |
First Reply from Silver GT
Well, I guess well have to wait and see -Ti |
okay guys where gonna need to pool everything together that we know.
My relay has ten pin plugs on the back of it... kinda looks like this ![]() I also didn't get the male side of the harness for the JDM relay.. so I had to make my own.. luckily I had an extra harness plug layin around and only had to add two new wires into it to make it work and the part numbers on the back of my relay are as follows: Green circut board #:183362 Harness (female side) #:361-2030 That how to is very helpful.. but think I will have to rely on the pin numbers and not the wire colors. If someone else has the 10 pin style that came with the stock wires still on it PLEASE follow the diagram above for the #'s Like: 1:white with blue strip 2:pink with silver spots ETC -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
okay thats weird then TI.. cuz the harness I used had those wires EXACTLY before I added two extras.. but why the 2 extra pins in the female harness????
Also.. some bad news for you guys... the mirror swap doesnt work on the drivers side.. at least not like the pass did try adding washers to some of the screws to give the assembly more of an angle and that works but the mirror sticks out too far and when its folded back will hit the part of the mirror attached to the door. this weekend I am gonna try and tear apart both mirrors.. USDM and JDM and see if I can swap the mounting part inside.. will photoshop some pics to explain better what I am talking about -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Hey Never, Just thought about it
I did that drawing with the wiring pointing to me, and the harness plugged in. If you at looking at the front of the harness (the part that plugs in, the just mirror the image over. I dont know why there are 2 extra pins either - hum. This might be bigger than I thought. I'll do some work this weekend. |
well if you read the howto thing all the wires are the exact same as ours and his except theres one extra wire in his..
I'm gonna try and get the drivers working TONIGHT! LOL his how to seems pretty straight forward though and I got a ton of extra harnesses with my mirrors so hopefully I can figure em out -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
hey one of you guys.. do me a favor really quick.. run out to your car with the JDM relay and plug it into your stock wiring harness and see if the mirrors will work like up down sides.. according to this guys howto it should
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
Hey Neverstop! You want an avatar that has a seemless loop to it? Cause here it is.
![]() -------------------- ![]() Project ST204.5 99.88946% complete... |
naw takes too long.. what I want is my MIRRORS to do that!
errrrgh,., think that guys howto is not accurate for the USDM celi -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
just some posts about them from the UK board
http://www.celica-club.co.uk/cgibin/phpbb2...pic.php?t=20650 http://www.celica-club.co.uk/cgibin/phpbb2...pic.php?t=18374 http://www.celica-club.co.uk/cgibin/phpbb2...pic.php?t=14714 all info is good... -------------------- |
I give up
is there room on that bench..... |
so no one ( USDM people ) have gotten these to work ?
Not that I know of.. I have gotten all of the functions to work at one point or another but can't seem to make em all work with the same wiring..... Its like 50% of them are + leads even though thats impossible for them to all be that way.... the retracing mirrors seem to work where the current is reversed threw the same 2 or 3 wires but cant seem to figure that one out either I have tired wiring it as close as possible to the way the Howto said... NOPE dont work, have tried matching the same pins.. not that either... have color matched.. nadda.. have tried hit and miss.. all that got be was a shorted out circut that I managed to fix Im starting to wonder if my relay was damaged to begin with but cant see ne visable signs other than the short I put into it ![]() I can get the mirror to work just fine by using a batter and some wires..and can get power to go threw the relay using a wire tester but when I hook the wires up to the mirror via the relay it DOENST do nething... theres even power to the wires@! and the same pins... might be a problem with neutral/chassie wire but who knows have tried running a seperate ground to the chassie and a power via the relay and that didnt work but the wire was hot so it shoulda worked -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
I'll try my JDM relay this weekend
jeez
![]() If the mirror (folding motor) works when you hardwire it to a battery then there is still plenty of hope for this. worse comes to worse, get the left right up down to work (or not) and harewire the folding using $3 relays to reverse the polarity -------------------- |
you have to use the JDM control not the usdm one...it will never work with any usdm parts
that is my JDM control unit. I have all the JDM peices, including the relay... and i'm still stuck. ![]() -Ti |
damn I thought you guys would make it easy for me. Has Anyone tried hooking the mirrors up to a battery and figuring out the functions of each wire ? still havent received mine yet. Wish I could shed some light.
well since you have EVERYTHING you should be the one to figure this out for us ![]() LOL there should only be like 3 or 4 wires you will have to hook up
yea tried that and got every function to work but not at the same time or nething like that... its suck a bish to figure this out ![]() -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
if he has everything shouldn't it be a straight wire up?
control switch to relay box relay box to mirror? oh and so we clarafi things......control switch is the one were you push the buttons relay is the stupid black box that TI has and the mirrors are the things on the outside of your car |
The mirrors are on the outside ? opps
![]() NEVER, you might want to try using a relay or 2. Have you wired relays before ? If you need to reverse a polarity use these diagrams here (relay diagrams) also, you said you can make the mirrors move (fold) with a battery hardwired right ? What wires and what polarity ? -------------------- |
the two wires on the out side of either side (2 farthest left or right wires) polarity doesn't matter one way will move out and one way moves in
yea I just used a little 9vlt battery think some of my prob is I had 3 shorts in my circut board.. I did one of em but never noticed the other 2 cuz they where hidden under some whitish goey ****. I soddered in some copperwire to fix everything and hotglued overem so hopefully that helps.
not quite but almost.. he will still have to splice into the USDM harness to make it all work but that should only be power and ground/chassis ***BTW THERE IS A RELAY BOX ON EBAY - DON'T BID ON IT ITS MINE!!!!!!!*** its just for toyota.. the guy didnt know what vehicle it was for but still its mine ![]() -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
that link might of well just said,"AHTEJAHTAWJTKJAKTHJAHTJA THAJHTKA A HATJHE ATHATHKAKJKDCNEKC NIOMEAO;NGAN AJKLSDJFLJLA" cus thats about as much since as it made to me ![]() -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
I'm sorry to hear that
![]() I will have my mirrors and switch in 6 days and on Wednesday I will be installing them. I will probaly get buy two $3 relays from radioshack to replace the toyota one because that is all it is. NEVER, learn about relays !!!!!!!!!!! you are buying one. You are going to need to know how to install it properly. I wish you guys lived close to me, I would be able to get these done. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) ![]() |
Batman, you wire the harnesses and they will come.
Get it working and name your price. -------------------- Member of Team 5sfTe
![]() Enthusiast ![]() Joined Nov 4, '04 From UK Currently Offline Reputation: 0 (0%) ![]() |
Hey guys, the panic's over, the doctor has arrived
![]() My name's Graham, I'm from merry olde England, I've got a '98 Celica GT, and I've fitted JDM electric folding mirrors and made them work ![]() So any questions you've got, ask away. Firstly, any of you that have got a control relay, throw it away. You don't need it! Next, for anyone who hasn't already got it, here's the circuit diagram for the existing mirrors on the USDM cars http://www.yellowsun.plus.com/how2/photos/cirdiag2.gif ![]() This post has been edited by SilverGT: Nov 4, 2004 - 10:04 AM |
That's what I'm talking about !!!!!!!!!!!!!!!!!!!
How the JDM mirrors work.
There are just 2 wires for the retractor motor, blue and green. If you apply power to one wire and ground the other, the motor runs one way. If you reverse the polarity it runs the other way. The motor has internal limit switches to switch it off when it reaches the end of it's travel, so the power can be left on all the time. The connections on the JDM control. ![]() ![]() 1 - retractor motor 2 - retractor motor 3 - spare 4 - left vertical adjuster 5 - chassis 6 - power +12v 7 - right horizontal adjuster 8 - right vertical adjuster 9 - common feed to adjusters 10 - left horizontal adjuster As for relays, I take your point about using them to save the switch, but in this case the motor current is tiny and I wouldn't have thought it necessary. The corresponding USDM loom colors 1 - retractor motor 2 - retractor motor 3 - spare 4 - left vertical adjuster - BR/Y 5 - chassis - W/BK 6 - power +12v - GY 7 - right horizontal adjuster - LG 8 - right vertical adjuster - LG/BK 9 - common feed to adjusters - LG/R 10 - left horizontal adjuster - BR/W GY = Grey W = White BK = Black BL = Blue BR = Brown R = Red Y = Yellow GR = Green LG = Light Green This post has been edited by SilverGT: Nov 6, 2004 - 6:22 AM |
thanks SilverGt, i'm the one who emailed you
Are you sure that is the controls for ALL JDM control units? I only ask because I board looks different -Ti |
And one more.... yeah
Now assuming the break down you gave us above is correct for all models, how do we go about working with it. Does the stock USDM harness plug right in and all we have to do is splice in the two extra wires for retract and expand? Thanks -Ti |
I've got no idea. The truth is I've only seen the one I've got, and I never got to see the car it came from. |
The JDM plugs and sockets are different to the ones in my car, so no, it didn't just plug in. You could cut the plugs off and just join up the new wires, but I choose to splice in behind the plugs so that all the original stuff is still there. But in essence, all you have to do is connect up the existing wiring to the new control as the old one was, and add the 2 wires for the retractors. |
Sweet, I recieved my mirrors today. SilverGT thanks for the great info ! Could you take pictures of your wires and how they are spliced.
also, how did you run the retract wires up to the mirror ? Thanks, DEF -------------------- ![]() I will return one day. |
yea your pins are different then mine for the control...
i have 3 on top and 5 on bottom 1 in the top left two on the top right and five straight across the bottom |
oh and i don't understand a single thing on that last think posted
I've got a pink wire - anyone know what that does. Its part of the cut off harness thats in my JDM control unit......
-Ti |
this is how my wires are
3 top pins top left pin : brown wire w/ silver spots top middle pin but on the right side: blue wire w/ red stripe top Right pin: gray wire w/silver spots bottom pins from left to right: pink w/black strip pink w/white strip puke green w/black strip puke green w/red strip red w/ silver spots edit= all wires have silver spots lol This post has been edited by playr158: Nov 4, 2004 - 10:42 PM |
wow thats completely different |
Oh yea!
BE JEALOUS!!! got all functions to work.. and I ended up not even using the control box.. will post more later as to how.. just dont have time at the moment -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 13, '03 From California Currently Offline Reputation: 2 (100%) ![]() |
ass
-------------------- 2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3 gone but not forgotten 2008 Space Grey BMW Z4 ///M 2009 Black Honda Civic LX Coupe 2006 Magnetic Black Nissan 350Z 2007 Crimson Red BMW 335i Coupe |
![]() okay heres the quick version of how I did it.. will make a scematic of later on. Basically I used the stock control box to control the mirror functions ex up down lf rt. Then I used two relay boxes to reverse the polarity of the pos and neg for the retract. I also used a power window switch for the control of the mirror functions... wish it could of been different but this will work until I can locate a stock relay for the mirrors... that and my JDM control switch isnt in the greatest condition nemore. bascially what happense is when I push down on the switch the mirror fold in.. and when I push up on the switch the mirrors fold out. what happens is the wires coming out of the relays switch back and forth between pos and neg. I had to use all four of the retract pins on the mirror harness... what I did was ran the two lines off of the relays into two of the pins and then had to jump them to the other two pins for the retact on the other side of the harness.... you have to cross the wires to ex: if you look at the mirror harness and look at the outer pins there are a total of 4 pins.. two on each side that are vertical. you need to plug both wires from the relays into these and then jump both of em to the other side... but you have to make the wires cross instead of going straight across.. this might be confusing I kknow.. will lay it out clearly for you guys sometime either late tonight or tomorrow sometime... you will know real quick if you have got em wrong cuz it will make the power blink off in your car ![]() -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
you used relays ? nice. I hope that link I posted helped in some way. I will have mine and wired in about a week
your an ass never.......how you do that then not give a CLEAR EXPLANATION you only talk in neverstop speak DAMN YOU
ok,who has 5th gen mirrors and who has 6th gens.
I have 6th gens. Dan has 5th gens ti has 6th gens Neverstop ?? Batman has 6th gens Dont want everyone confused on wire color anymore or pin location -------------------- ![]() I will return one day. |
ah see thats why its different i HAVE 5TH gen mirrors
damn it.....looks like i have to find a 5th gen board and check around |
To splice the wires in I used these little things ![]() I don't know if you have these over there. You don't have to cut or strip the wires, you just lay the wire in and close it up with a pair of pliers. ![]() This is the best photo I've got of the new wiring. How did I run the retract wires up to the mirror? The new mirrors already have the wires for the retractor motors. I added wires in mine to supply the heated glass and I explained how I did that on the How 2 page. |
well that explains alot. I also figured mine out. My JDM relay is an acting polarity changer. My pink wire goes to the relay, from there I have the blue and green (retractor + and - ). So when I push my button, it sends the signal to my relay and thus changes polarity. I dont think it'll be hard at all now, thanks to the USDM loom break down Silver GT gave us. What I'll do when I get back (monday) is check my stock relay to see if they are the same unit. My JDM mirrors/relay/control unit came off a 97 and I have a 97. So if they are the same, I'll tell you which pin the pink (or whatever color) goes to and which pins the green and blue come off of. This way we can all have the JDM control unit working in our cars. ![]() -Ti |
mine are 6gc ones
curse you all wtf am i supposed to do
Take them apart and have a look at the motors. Toyota may have used the same ones and you may be able to build them into your existing mirrors. |
nice. Relays are fun and easy
![]() EDIT: playr158, just put the motors in your mirrors. Then just wire the motors to work. With the 2 links posted - http://www.yellowsun.plus.com/how2/retractmirror.html and http://www.radcastro.com/Projects/Project+ST2GT4/580.aspx you should be able to mount the motor your existing housing and then just wire them in. This post has been edited by Batman722: Nov 5, 2004 - 10:01 PM -------------------- |
![]() the blue arrow is the main gear.. I had to redo the glue inside cuz the driver side mirror was loose and it would spin out too far and not let the mirror move back out. the red arrow is pointin at the powerthingy for the motor.. I had to reset the motor a few times when I was figurin out everything.. unhookin that and then pluggin it back in seems to be the way to do it ![]() This post has been edited by NEVERSTOP: Nov 5, 2004 - 11:11 PM -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
after doing some research I have a question for SliverGT
looking at the UK how 2 on http://www.yellowsun.plus.com/how2/retractmirror.html The old and new wire colours for the control units are the same so you just join colour to colour Control unit Power = GY Chassis = W/BK Common feed = LG/R Right Vert. = LG/BK Right Hori. = LG Left Vert. = BR/Y Left Hori. = BR/W Retractor + = R/Y Retractor - = BL/W and looking at your USDM loom colors The corresponding USDM loom colors 1 - retractor motor 2 - retractor motor 3 - spare 4 - left vertical adjuster - BR/Y 5 - chassis - W/BK 6 - power +12v - GY 7 - right horizontal adjuster - LGR 8 - right vertical adjuster - LGR/BK 9 - common feed to adjusters - LGR/R 10 - left horizontal adjuster - BR/W 2 wires don't match up - the RH and the common feed are switched. Just a mistake ? Are you sure the USDM / UK / JDM control unit wires all match up ? or are they different with the USDM (2 wires) ? EDIT : also, the + and - from the mirrors just go directly to the + and - of the control unit ? This post has been edited by Batman722: Nov 5, 2004 - 11:21 PM -------------------- |
After more research, NEVER, that is some funky riggin
um if I read that right YES I just ran and external switch completly independent of the JDM control switch.. in fact once all the wires are completly ran and everything is tucked away nicely the only thing that will be JDM is the mirrors them selves and the harness that is with the mirrors... I will wire everything up so the harness that pluges into the female side of the mirror will be wired into the Door harness Right now theres just a buncha wires inside the car to make everything work.. I am waint for the adhesive to dry completely before I hook both mirrors up at the same time but I have gotten each to work by themselves.. just did the driver side with it all taken apart and the pass fully assembled. I see no reason why this setup shouldnt work and is a quick easy fix for those that didnt get the stock relay. also think until we get the actual wiring all figured out this would be the route to go ![]() -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
can someone explain what i have to do with these damned 5th gen mirrors??????
swap all the motors into my stock mirrors? how would i wire? switch? keep the stocker? |
Lo-Fi Version | Time is now: April 24th, 2025 - 9:11 AM |
