Valve cover thing, won't stay done... why? |
Mar 12, 2003 - 9:22 PM |
Enthusiast Joined Oct 9, '02 From San Diego, CA Currently Offline Reputation: 0 (0%) |
Then 2nd valve cover of 4 keeps popping up every so often which results in a low idle'ing and a choppy ride if below 2k rpm. So I messed around with it and for some reason its much looser than the other three covers, does anyone know how to remedy this? Gets annoying to have to push it back down every so often. Thanks for the comments.
Mar 12, 2003 - 9:39 PM |
Enthusiast Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
what do you mean by valve cover? like the spark plug wire keeps popping up? how do you notice if it's in the engine bay?
-------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Mar 12, 2003 - 11:37 PM |
yeah,well, my car was running crappy a few weeks ago, so I popped my hood and saw it popped up half way and i pushed it down and it was running good again but now it frequently pops up and is looser than the other ones. |
Mar 13, 2003 - 12:11 AM |
Enthusiast Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
try to crimp down the end of the plug wire. If it keeps hapening, just get new wires, it's a good thing to do, you know....
Mar 13, 2003 - 1:04 AM |
Enthusiast Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
did u recently change ur spark plug wires? cuz if you did then your problem is that the rubber boot off of you old ones is stuck down in ur head and that is a bish to get out.. I had to take the head off to get at it... otherwise just try crimpin it like fallenhero said
-------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Mar 13, 2003 - 2:57 AM |
Thanks for the advice, I have been "crimping" it. It stays down for a few days but slowly makes its way up, I guess I need a new wire.
Mar 14, 2003 - 12:03 AM |
Unless I'm mistaken, TRD makes wires for the 7A and the 5S
Mar 14, 2003 - 6:08 AM |
Enthusiast Joined Sep 5, '02 From Phoenix, AZ Currently Offline Reputation: 0 (0%) |
TRD wires are hella expensive. If your gonna get new wires you might as well get some that will help you out with voltage and stuff. Check the parts database.
Lo-Fi Version | Time is now: December 4th, 2024 - 8:16 AM |
