> remote starters, on a manual
post Oct 23, 2004 - 11:28 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
I am going to get a remote start kit for my car. I've been told that no shop will install it on my car b/c its a stick. If that is truly the case, has anyone ever installed it on their car, and if you did, can you give me a how to on installing it?
Thanks alot,
Jeremy
Oh yeah, whats a good brand to get. I don't need an alarm really, just the remote starter.
Replies (1 - 19)
post Oct 24, 2004 - 3:15 AM
Gilbert_619
Joined Sep 10, '04
From san diego
hmm why not stick? what about when people all the time leave there car in gear ....will it start?
post Oct 24, 2004 - 7:03 AM
Hanyo
Joined Aug 16, '03
From Bay area
the car will not start.. but roll into a wall or another car.. ( alot of damage)
there are alot of people including myself that have install a remote start alarm in the celica.
the basic wire diagram is located on the sticky at the top of the page.
You will need a way to defeat the saftey clutch switch.
since i own an automatic. I will leave this step to the other people on the forum to answer your question.
the install is relatively simple. hook up the alarm (or remote start) wire to the coresponding wire in the celica wire harness.
post Oct 24, 2004 - 11:58 PM
Jeremy1210
Joined Dec 16, '02
so anyone with a manual celica installed a remote start on their car that can help me out??
post Oct 25, 2004 - 12:12 AM
SEARCH
http://www.6gc.net/forums/index.php?showto...=remote+starter
http://www.6gc.net/forums/index.php?showtopic=13685&hl=
post Oct 25, 2004 - 8:22 AM
tigernate29
Joined Aug 19, '03
From KY
I installed a remote starter on my manual transmission celica a couple of years ago. You do have ot be careful when you start it. I left mine in gear once and drove through my wife's garage door while we were dating. Her dad wasn't too happy, but what was worse was I had to help him paint the garage door again. My point is be careful or you'll mess up and have to paint garage door with your in-laws.
post Oct 26, 2004 - 4:02 AM
soltrain
Joined Aug 19, '04
From Berkeley
someone on the boards made some kinda mechanism that only allowed the remote start to start if it was in neutral... but I never got so see what it was exactly..
post Oct 26, 2004 - 4:11 AM
Hanyo
Joined Aug 16, '03
From Bay area
the best solution is the get an alarm with a turbo timer
so the car will run for like X amount of time after you arm it.. so when you start it, it will never be in gear.
if you do this you will need to disable the safely clutch switch.
post Oct 26, 2004 - 9:24 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE (soltrain @ Oct 26, 2004 - 4:02 AM)
and that member is the owner - Coomer
back on topic:
you just need a clutch bypass sensor. Theres a sensor that is activated when the clutch is depressed, this is why the car wont start unless the clutch is in, or how cruise control turns off if you press the clutch. You need to bypass this. Then, its basically just an automatic. HOWEVER!!!!! You need to leave the car in neutral, I dont think this of a problem figuring I just set my ebrake and go.... but alot of people leave it in neutral. I think Chris (Coomer) created a relay that would only let him start it if it was in Neutral. Its probably more explained in the two topics that Batman posted.
-Ti
post Oct 27, 2004 - 11:20 PM
soltrain
Joined Aug 19, '04
From Berkeley
Actually I think it was trdevelopment that I was remembering, it's in this thread:
post Oct 28, 2004 - 1:07 AM
yellowxboy
Joined Apr 17, '04
From Southern California
TRANSPONDER BYPASS MODULE
hope this helps. i bought my remote starter from this website. its really cheap. quality is good too. i have an auto but the link above has this "bypass module" that bypasses the cluth safety for stick. just be careful and make sure ur e-brake is on when ur not driving biggrin.gif
post Oct 29, 2004 - 6:42 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (yellowxboy @ Oct 28, 2004 - 6:07 AM)
bypass modules is used for people who upgrade there factory car alarms to an aftermarket one.
This module will "bypass" the factory one and let the aftermarket one work without setting off the factory alarm.
post Oct 31, 2004 - 11:27 PM
SilverCell94
Joined Aug 30, '02
From NYC
get a Clifford alarn w/ remote start, they have great systems for manual.
your car can be in gear too.
This post has been edited by SilverCell94: Oct 31, 2004 - 11:28 PM
post Nov 1, 2004 - 1:32 PM
what the heck are you smoking^^^^^^^^^^^^^^
think about that for a second.....with out the clutch being PHYSICALLY pushed in you CANNOT remote start your car in gear WIHTOUT rolling into sumthing/someone
an manual car with remote start MUST BE LEFT IN NEUTRAL
post Nov 1, 2004 - 1:43 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
yeh it was me guys i did have the mechanism for it not 2 start in gear but somehow it messed up the senser and now it starts up if its in gear i have to take it to my mechanic again to see what happin to it... ill let you guys know how to make one cause mine was fabricated when i get to it.
post Nov 1, 2004 - 2:12 PM
sorry that doesn't sound to reliable if its messin up that bad....
i'll stick with leaving my car in neutral with the e-brake up
post Nov 1, 2004 - 11:54 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
QUOTE (playr158 @ Nov 1, 2004 - 7:12 PM)
listen bud i ment to say the remote start was working witht he mechanism but now its not. once i find out whats wrong with that mechanism ill let you guys know but my remote start still works.
post Nov 4, 2004 - 9:13 AM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
manual autostart with alarm
manual autostart
post Nov 4, 2004 - 11:59 AM
Jeremy1210
Joined Dec 16, '02
both of those are some b/s IMO. Any remote starter can be used on a manual. You still have to bypass the clutch sensor and neither comes with any thing to do it with.
I installed mine on sunday and it took like 1 hour to do. Very easy. I had to bypass the clutch system. My cruise control doesn't work b/c the clutch wires are touching, but I am going to buy an on/off switch that makes it work. When the wires touch, and you are in first gear, its like an automatic...Pretty cool
Bottom line: Need to bypass the clutch to have a remote start in manual and leave it in neutral
This post has been edited by Jeremy1210: Nov 4, 2004 - 8:13 PM
post Nov 4, 2004 - 6:19 PM
SilverCell94
Joined Aug 30, '02
From NYC
QUOTE (playr158 @ Nov 1, 2004 - 11:32 AM)
what are you talking about?
clifford developed a system for manual transmissions. you CAN START YOU CAR with the caR in gear.
for those who know clifford alarms they make the top of the line alarm system for cars. the local clifford dealer wil have a promotion contest every year or so.
the contest, anyone who can break into the car, start it, and drive it around the block (system will stall out the car)will win whatever car they are giving out.
time frame they give you 1hour
well back to the subject, my girl has the system in her car (manual) and it starts it up perfectly, doesnt have to be in gear.
Lo-Fi Version Time is now: November 26th, 2024 - 1:26 PM
