Enthusiast Joined Mar 14, '03 From College Station, Texas Currently Offline Reputation: 0 (0%) ![]() |
Hey Folks,
I just replaced my original clutch at 131K mi. I installed an Exedy Sportline clutch Kit. Resurfaced the Flywheel and used the same oil that the dealership uses. Now, when cold, its hard to shift into 1st, and when shifting into 3rd, all the time, it grinds a little. I did not grind before the clutch replacement, but the original clutch was slipping, so that 's why I replaced it. Any ideas about why its hard to shift into 1st and grinds into 3rd? Thanks, SKippy344 ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
syncros
![]() -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) ![]() |
that is not funny at all..i am on 131,886 miles..and i don't want to change my clutch...not yet at least
uhh oh...135,000+ here...
![]() ![]() -------------------- Former Team 5SFTE pro member ;)
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Sep 5, '02 From Phoenix, AZ Currently Offline Reputation: 0 (0%) ![]() |
I take it that you changed the clutch yourself, which for starters was probly a no no!
Enthusiast ![]() ![]() Joined Jan 16, '03 From Wichita KS Currently Offline Reputation: 0 (0%) ![]() |
I have the same problem with third, It is harder to get in than any other gear and it sometimes grinds especially when its cold.
someone told me it was the syncros to. don't know what i can do about it and not end up spending alot of money. |
![]() Enthusiast ![]() Joined Oct 21, '02 From Toronto, Canada Currently Offline Reputation: 0 (0%) ![]() |
Try changing the manual transmision fluid, it may not solve the problem entirely, but it should reduce the grinding.
if it happens too often that means its a syncro problem, you may need to have the tranny redone. i had to have mine redone at 70K miles... luckly it was under warranty.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 13, '02 From Hawaii Currently Offline Reputation: 0 (0%) ![]() |
Same as my friends turbo'd civic. 3rd always grind. Thats why he jumps from second-to-fourth then third-to-fourth again.
Enthusiast Joined Mar 18, '03 From Salt Lake City,Utah Currently Offline Reputation: 0 (0%) ![]() |
Hey man consider yourself luck mine is grinding into 3rd and it only has 86000 miles on it tell me if you find a solution.
![]() Enthusiast ![]() ![]() Joined Oct 1, '02 From PA Currently Offline Reputation: 0 (0%) ![]() |
yeah, its like hard for me to downshift into first when im moving really slow. i pretty much have to come to a complete stop to shirft into first.
people dont like to listen...
ITS A SYNCRO PROBLEM -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Alright folks, I think I'm gonna break down and take it to a Tranny shop and let them give me the bad news about cost to fix the grinding/not going into gear problem.
I'll let you folks know what they say. |
![]() Enthusiast ![]() ![]() Joined Apr 28, '03 Currently Offline Reputation: 0 (0%) ![]() |
Yeah, I got 157k miles on mine and 3rd has been grinding for the past 50k
Enthusiast ![]() Joined Nov 13, '02 From Bangor, Me/ Huntsville, Alabama Currently Offline Reputation: 0 (0%) ![]() |
synchros.....double clutch....
![]() Enthusiast Joined Nov 4, '02 From montrose colorado Currently Offline Reputation: 0 (0%) ![]() |
mine starting to do in 3rd, its got 61,000k. i'm going to look for TSB's when i get to work and see if toyota had a problem with the 6th gen's trans i'll let u know what i find. and yes it does sound like synchros, but its kinda weird that we r all having the same problem. if i don't find anything in the TSB's i may call tech line.
Enthusiast ![]() Joined Jun 4, '03 From KY Currently Offline Reputation: 0 (0%) ![]() |
i put 139k on my original cluct/tranny...never had a 3rd gear problem, and i drive min elike i stole it and am making a run for the border
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) ![]() |
I just bought my celli its got 52k miles and its doesnt like to go into 1st gear if im goin about 5mph.... I thought toyotas just did that? Dont tell me somins goin at 52k miles!
Enthusiast ![]() Joined Nov 3, '02 From mass Currently Offline Reputation: 0 (0%) ![]() |
yup same here, 110 000 miles, wont go into first gear unless im barley moving, second i have to jam in pretty hard, and 3rd geear grinds a bit sometimes, gonna have to try changing the tranny fluid, although i just got a new clutch, so was it changed?
does it work when you guys rev match 1st?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) ![]() |
Your car isnt supposed to go into first easily at all unless you make a nearly full stop.....thats the work of synchros. So when you go to stop, only downshift to 2nd, then press in your clutch and gently let the gear slide into 1st. The gears only line up correctly when your doing like maybe 5 mph or under, due to the synchros that have to line up your gears correctly.
EDIT- Also, my gearbox grinds a little when shifting from 3rd to 4th....so i have a similar situation cuz my car has high mileage and probably needs some new synchros too. This post has been edited by Silver94CelicaOwner: Jun 7, 2003 - 6:07 PM -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Enthusiast ![]() ![]() ![]() Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) ![]() |
my 3rd gear has started doing this yet it only does it ocastionly and its normaly completely fine, I even had it happen when I double clutched, anyone have any idea?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
hmm ya i sometimes have problems in 2nd gear. When i decide to downshift into 2nd gear at 40 mph at 4300 rpm's it can tend to grind every once in a while. But in 1st or 3rd i have no problem downshifting. In 1st gear i can downshift when im going 30mph at 5,000 rpms and 1st gear tops out at 35mph. the same with 3rd gear. so why is it that its only 2nd gear that does it for me. The previous owner was a chick. i got the car at 75,000 miles
-------------------- Group buy to replicate Narrow E series transaxle parts
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) ![]() |
my 3rd gear has started doing this yet it only does it ocastionly and its normaly completely fine, I even had it happen when I double clutched, anyone have any idea? Its time to rebuild the tranny or replace it. -------------------- "To Protect And To Serve The Wealthy" -POLICE
chanke the tranny oil.
Check the sticky. -------------------- |
my 3rd gear has started doing this yet it only does it ocastionly and its normaly completely fine, I even had it happen when I double clutched, anyone have any idea? Its time to rebuild the tranny or replace it. yay haha, my dad said to bleed the clutch fluid, and I just did a transmission fluid like 5000km ago. |
Lo-Fi Version | Time is now: April 23rd, 2025 - 11:38 AM |
