> Check this out......, 3S harness conversion
post Nov 3, 2004 - 4:13 AM
0Re0
Joined Nov 13, '02
From Hawaii
If someone could ask them If theycan possibly make some for our ST & GT then .....3s swaps would be a lot easier.... Just plug and play biggrin.gif If this goes through then someone set up a group buy!!!!!
>>http://www.autosportwiring.com<<
AutoSport Wiring has agreed to make a set of wiring harness extensions for the 5S-FE / 3sgte / Supra ECU. With this cable, you can do all sorts of modifications without touching your stock harness. This cable plugs in between the main wiring harness and the ECU itself. SO with this harnes you can wire in all your a/f, ignition, timing and any other controls and guages witout having to touch your stock wiring. Another benefit of this item is that you can make the connections outside of the car and solder everything up nice and clean.
Will work with:
89-92 Supra
91-95 MR2
90-93 Celica All-Trac
Gen 3 Camry
Click here.....
This post has been edited by 0Re0: Nov 3, 2004 - 4:18 AM
Replies (1 - 12)
post Nov 3, 2004 - 4:22 AM
Magic
Joined Mar 30, '03
From Cyprus
Great site.Did you email to them???
post Nov 3, 2004 - 4:38 AM
0Re0
Joined Nov 13, '02
From Hawaii
nope......my wrist hurt and im too lazy to write! Someone please ask! biggrin.gif
post Nov 3, 2004 - 4:52 AM
tufy
Joined Dec 3, '03
From Cyprus
QUOTE (0Re0 @ Nov 3, 2004 - 9:38 AM)
still didnt finish that big picture.
btw i send you a p.m about your turbo
post Nov 3, 2004 - 11:22 AM
nik
Joined Sep 30, '02
i asked them a few weeks ago if they could make me one for my greddy Profec E-01 and injector/igintion so i didnt have to cut my stock wires it was only $145 biggrin.gif
post Nov 3, 2004 - 11:33 AM
Pali_playa
Joined Apr 4, '04
From VA, USA
so wait im confused, is this so u can just plug up the diff harness in a 3s swap, cause if it is, thats really nice
post Nov 3, 2004 - 11:35 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
What about the 7a-fe .. dem bastards..
post Nov 3, 2004 - 12:08 PM
st202gt
Joined Jan 17, '03
From Fresno, CA
they are having a group buy in the toyota nation form.....................
i was reading it back couple weeks ago.
post Nov 3, 2004 - 12:17 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
Some one has got to get them to do this for us, and at that price its practically free.
7afe and 5sfe
Team 6gc 2005
FallenHero
Joined Dec 26, '02
From Alabama
That's impressive stuff...
post Nov 3, 2004 - 12:22 PM
dabbill
Joined Aug 26, '04
From Vancouver, WA
post Nov 3, 2004 - 12:25 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
idk
i think all it is is to make wiring in gauges and piggy backs more easily and have better capability to go back to stock.
notice how each harness is all white, except for a select few wires?
they are probably knock, rpm, speed, maf/mas/map signal, etc.
you could have them custom make a really long one for the 3s swap, but you will still need to repin it.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Nov 3, 2004 - 10:17 PM
while its possible to make a plug in harness like that for the 6th gen to 3sgte swap, it could only be done for the ecu section of the wiring. the main engine bay fusebox would still have to be rewired by hand.
so, it still has to be a custom job in the end.
Lo-Fi Version Time is now: December 4th, 2024 - 12:23 AM
