![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 15, '02 From Vidor, TX Currently Offline Reputation: 1 (100%) ![]() |
ok guys heres my prob. i installed a Greddy Prefec B into my car today.... As soon as i react .2 bar the engine cuts off till i let off the gas .... any suggestions????
-DMC |
sounds like you are hitting fuel cut.
did you disconnect and plug the Tvis? you can not correctly control the boost with that line still hooked up. im not sure what .2 bar is in psi. but stock fuel cut should be around 12-16psi depending on what year your motor is. -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) ![]() |
.2 bar is equivalent to about 3psi
it's roughly 15psi for every bar -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 10, '03 From Connecticut Currently Offline Reputation: 11 (100%) ![]() |
CEL coming on?
yeah pull the CEL codes and see what they tell u.
problem solved thanx supersprynt
so, what was it?
im curious too!
Lo-Fi Version | Time is now: February 22nd, 2025 - 9:53 PM |
