Fuel Cut/Loss of power @ 0 lbs. |
Nov 23, 2004 - 11:50 AM |
Enthusiast Joined Aug 27, '04 From Orange County, CA Currently Offline Reputation: 0 (0%) |
My VAC is between -19 & -21 at idle, but when I try to boost and it reaches 0 lbs, I lose power. My RPMs are normally around 2500-3000 when this happens. If I punch it (which I hardly ever do) I can get it above 0 lbs and boost fine.
The turbo has no shaft play, and was installed a couple of weeks ago. I'll be bringing it down to the shop today, but wanted to see if anyone here knew what it might be. Thanks. -------------------- |
Nov 23, 2004 - 12:07 PM |
my guess would be boost leak, or exhaust manifold leak. do you have a fmic, or topmount?
Nov 23, 2004 - 12:12 PM |
how do you have mbc hooked up?
Nov 23, 2004 - 12:44 PM |
Enthusiast Joined Nov 15, '02 From Vidor, TX Currently Offline Reputation: 1 (100%) |
alomost the same prob i had ... cap off the VAC line between the wastegate actuator and the TVSV
Nov 23, 2004 - 12:52 PM |
I dont think he has a 3sgte - atleast his profile doesnt say so.
Nov 23, 2004 - 1:24 PM |
I have the 5SFTE
The right side VAC line on the wastegate actuator is capped. I have a front mounted Spearco Intercooler. Thought that it was a manifold leak as well, checked this morning, everything is tight. I used the correct torque setting when installing the new turbo. I'll get some pictures of my VAC line setup when I get home. This post has been edited by erics1one: Nov 23, 2004 - 1:25 PM -------------------- |
Nov 24, 2004 - 11:03 PM |
Not all vacuum lines were zipped tied.
Zipped 'em all up, reset the ECU, problem went away. Must have been a loose line. Would be nice if it was my only problem -------------------- |
Nov 25, 2004 - 12:47 AM |
yeah, loose vac lines= boost leak. i noticed that the metal hose clamps you can get at pepboys work a lot better then zipties, so you might want to look into those if your ties fail.
what type of vac readings to 5sfTes get at idle anyway? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Nov 25, 2004 - 11:35 AM |
It usually sits between -19 to -21.
I still get a lot of resistance/hesitation below ~2700 rpms untill the boost kicks in. Pretty sure thats typically normal with this kit, but am interested to see how much a dyno tune will correct which I plan on doing soon. -------------------- |
Lo-Fi Version | Time is now: January 11th, 2025 - 4:55 PM |
