> making boost, whistling
post Jan 7, 2005 - 1:56 PM
tigernate29
Joined Aug 19, '03
From KY
I am having some trouble making boost. I installed a different bov last week, and before that my turbo made boost very easily. Now I can hear the turbo whistling but it is showing that I am not making boost. I wonder if maybe there is a vacuum leak somewhere or what is happening. Anyone have any ideas? The bov is a megan racing bov. adjustable. Please help if you have any ideas.
Replies (1 - 13)
post Jan 7, 2005 - 2:05 PM
1bwilson
Joined Aug 30, '02
From Maryland
Is your BOV set too loose? As in it bleeds to early?
Member of Team 5sfTe
post Jan 7, 2005 - 2:07 PM
tigernate29
Joined Aug 19, '03
From KY
QUOTE(1bwilson @ Jan 7, 2005 - 7:05 PM)
[right][snapback]231104[/snapback][/right]
I can't really tell. As soon as the turbo starts to make boost the whistling sound starts. I have adjusted the bov to many various positions to see if that was the case, but all end in the same result.
post Jan 7, 2005 - 2:09 PM
1bwilson
Joined Aug 30, '02
From Maryland
Can you rev it and locate the sound? Its odd that you juet replaced the BOV and nothing else and this happned.
post Jan 7, 2005 - 2:15 PM
tigernate29
Joined Aug 19, '03
From KY
QUOTE(1bwilson @ Jan 7, 2005 - 7:09 PM)
[right][snapback]231108[/snapback][/right]
I've tried to rev it up and locate the sound but to no avail. It only makes this sound under boost, and when I rev my engine in neutral it only goes under vacuum pressure. I have no clue as to what is going on.
post Jan 7, 2005 - 2:38 PM
what bov do you have?
i have the same issue with my hks
post Jan 7, 2005 - 2:45 PM
nik
Joined Sep 30, '02
maybe tighten the adjusten screw if you have the same probablem swap bov and see if it is just a bad bov
This post has been edited by nik: Jan 7, 2005 - 3:36 PM
post Jan 7, 2005 - 3:17 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
first off, what vacum line are you guys connecting the BOV too?
post Jan 7, 2005 - 3:38 PM
nik
Joined Sep 30, '02
QUOTE(sphinx @ Jan 7, 2005 - 1:17 PM)
you guys
[right][snapback]231138[/snapback][/right]
i dont know if your asking me too or just nate and lagos
my line is coming off the manifold
post Jan 8, 2005 - 8:29 AM
tigernate29
Joined Aug 19, '03
From KY
QUOTE(nik @ Jan 7, 2005 - 8:38 PM)
you guys
[right][snapback]231156[/snapback][/right]
I tapped a barb fitting directly into my intake pipe about 5" off of the manifold which runs to my bov and boost gauge.
post Jan 8, 2005 - 5:42 PM
Newbie
Joined Nov 3, '04
From Colorado
Try tightning the BOV little harder.. See if the noise decreases.. Have you tried that? Are you holding any boost at all?
post Jan 8, 2005 - 10:09 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
did you buy the bov used or new??
post Jan 9, 2005 - 10:45 PM
tigernate29
Joined Aug 19, '03
From KY
I bought it new. I think that I just have an intake pipe loose somewhere. I am going to check all of them someday soon. If anyone has any other ideas of what the problem might be then let me know. Thanks.
post Jan 9, 2005 - 11:57 PM
i had a boost leak for the longest time. turns out that the screws on the front cover of my bov had gotten loose. those scews are what holds the gasket that seals when the bov closes.
Lo-Fi Version Time is now: November 25th, 2024 - 6:37 PM
