> Turbo?? How much HP??
post Mar 26, 2003 - 8:40 PM
ToYCeLi8
Joined Mar 6, '03
From South Central Los Angeles and Long Beach, CA
Well i know that there are different types of turboes and they vary from car to car. So i was wondering if someone can give me an average HP increase that the turbo will add? Or more specifically how much will these turbo kits add and are theyt worth it? Or do i just do the 3sgte swap???...
Burien Toyota turbo kit - priced at $2,500 and includes the following:
Toyomoto exhaust manifold
Garrett TB0344 turbo
down pipe
intake pipe
K&N air filter
intermediate pipe (between the turbo and throttle body)
HKS racing blow off/pop off valve
4 360cc Toyota injectors
map sensor
oil pan
all necessary couplings, clamps, vacuum hoses and fittings required to install the system.
OR
Toyomoto turbo kit - priced at $3,000 and includes the following:
Mitsubishi TDO6 turbo
Toyomoto downpipe
Haltech F9 additional injector system w/ additional injector
all nessasary piping and plumbing hoses and clamps
oil line and oil return is also included
Replies (1 - 19)
post Mar 26, 2003 - 8:52 PM
Guest_Matthew_*
well you can get a 5th gen gt-4 3s-gte (actually 2nd gen engine) for around 1500 at the right website (www.jarcoinc.com). and that base HP is 225 and about 187 at the wheels.. the burien kit (owner right here) gives you about 197 and 164 at the wheels. take about 1000 to put the engine in so for the same price you can get 23 more HP and that is all at 8psi. (for both systems) you can boost the 3s-gte to around 15psi on stock internals safely...also with the 3s-gte if you buy certain parts you can get 700+hp easily... the 5s-fe will never get that high...
that's just my opinion...if you disagree please don't talk sh*t about me...just state what you think. I'm sorry that I have to say that but this site is kinda getting like celica.net. Again just my opinion.
post Mar 26, 2003 - 9:12 PM
hioctane
Joined Nov 26, '02
most people would go with the swap. so just follow the flow and get an engine swap
post Mar 26, 2003 - 9:17 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
it all depends on the amount of boost you plan on running.
generally it is said that 11psi adds 100hp but it varies depending on how efficient your turbo is, what your exhaust is like, how big of an intercooler you have, etc. on the burien site it says that they were at 12 psi with no problems and that is non intercooled, so it could probably take more psi and make power more efficiently
those kits, while complete, are over priced(actually the burien kit is nonintercooled) if you but seperate components it will be much cheaper.
as for a swap, expect to spend $5000 for a complete job with a 225hp st185 clip. the swap will have a lot more down time but a lot more potential as well. you might want to consider emissions, if you have tough emmisions, you better find a friend in a test center that wont mind the missing egr and other emissions controls
really its up to you. if you want power sooner and with less down time, get a turbo kit.
if you can wait, go for a swap and then you can make some real high amounts of power with high reliability.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Mar 26, 2003 - 9:19 PM
Guest_Matthew_*
5 thousand dollar good lord that's a lot of money...i don't know where you get stuff done but i would shop around first... edit: dude i don't think you should have done this in 2 forums either...one of them will get deleted or moved..
This post has been edited by igotta5S-FEturbo: Mar 26, 2003 - 9:19 PM
post Mar 26, 2003 - 10:03 PM
west_minist
Joined Oct 27, '02
From Barbados
I believe that you should be able to get to 200HP.
I have not look at the info fully, but I am pretty sure that the 5SFE can hold on to atleast 160-180hp. But do not take my word for it.
The 5SFE from all F engine was really built to handle such stresses that a force induction engine would attained.
But witl forge internals, try it and see.
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Mar 26, 2003 - 10:11 PM
boosted_K2
Joined Aug 30, '02
From Michigan
QUOTE (97sccelica @ Mar 26, 2003 - 9:17 PM)
No but I don't buy it
Cause I'm...
post Mar 26, 2003 - 10:31 PM
ToYCeLi8
Joined Mar 6, '03
First of all I'm sorry for putting this in two different forums, i just wanted to see what was the best choice, and what were your opinions. So thanx for your help.
Now, about the turbo and the swap. Another member from toyotacelicaweb.com is doing the 3rd gen. 3sgte swap and he told me its costing him $5000 for the swap plus $1200 for the new paint job and he got the st205 clip. So if thats true then i guess.... i can save up some of that. But of course it will take me longer and i would just hav e the clip laying around for a while until i save the other $2k. I was planning on adding the turbo this June 9th, while i was on a short vacation.
Thats another thing, how long would installing the Burien turbo kit take? or any other turbo kit? I know that 3sgte swap does take some time and patience.
About the boost, I will sowly but surely be making my car faster and faster. Just like everyone is, but i guess if there is somewhat of a limit, i want to go to about 500 hp. Also i already do have a hook up here and there for the emissions test, so i dont have to worry to much about it. Thats mostly why i'm doing this. I've met the right people here and there so I'll hopefully be getting lots of help from my friends.
post Mar 26, 2003 - 10:43 PM
hiflytsi
Joined Jan 9, '03
From Concord, NC
Well, if no one beats me too it, everyone will say swap it out, unless you want to completely replace ALL of the internals of the 5s to get those numbers.
Edit-
I wasn't beaten until Coomer merged it at the exact same time i posted.
This post has been edited by hiflytsi: Mar 26, 2003 - 10:46 PM
I just merged this topic, so from now on, do not cross post.
post Mar 26, 2003 - 11:19 PM
FallenHero
Joined Dec 26, '02
From Alabama
We need to figure out a way to supercharge our cars. I hear GM is about to offer a SC for older model Cavaliers. Didn't somebody say they used toyota 7a's?
post Mar 27, 2003 - 12:00 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (igotta5S-FEturbo @ Mar 26, 2003 - 7:19 PM)
I kno that a st185 can be cheaper than $5000
but for all intended purposes, it is ALWAYS better to be prepaired to spend more. what if the engine needs some parts? what if something happens when installing and parts break.
or what if you decide to put in a better flywheel and clutch while the engine is out.
it is going to be a little under $2000 to have a st185 clip shipped to your door, atleast $1000 for labor, might have to have the wiring done by someone else ~$300, then misc parts ~$500
so yeah, you can easily do the swap for just under $4000. but if you have an automatic tranny, the cost will go up $500-$1000
post Mar 27, 2003 - 12:27 AM
Guest_Matthew_*
ok well when i got my front/rear clip of the st205 i asked about the st185 and he said 1500 for the front clip and 500 shipped to iowa...so take it like that....5000 is a sh*tload for any engine...i got the front/rear for 5500 shipped...
post Mar 27, 2003 - 12:51 AM
Charlie97L
From North Bethesda, MD
QUOTE (97sccelica @ Mar 26, 2003 - 7:17 PM)
my god 12 psi unintercooled and on stock 5s internals???!! you'll blow the engine to hell with that. 5 psi unintercooled is as much as you should get.
what you do depends on what you want! if you want mad power potential, go 3sgte. if you just want a little more oomph, turbo.
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post Mar 27, 2003 - 1:01 AM
No0bOne
Joined Jan 5, '03
From Bay Area
I'm sick of these silly questions...
post Mar 27, 2003 - 8:31 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
Well get used to them man, noone knows that there is a search button and "Sticky" posts at the top of different sections that explain all this already.
post Mar 27, 2003 - 3:53 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Charlie97L @ Mar 26, 2003 - 10:51 PM)
you are right Charlie, but i am pretty sure that they added an intercooler
so if you add an intercooler to the burien kit, supposedly you can run around 12psi.
but remember, do your research.
post Mar 27, 2003 - 3:57 PM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
i want boost damn it
im sick of being a broke college student
oh well less than 3 yrs from now
id be boostaholic
post Mar 27, 2003 - 11:41 PM
FallenHero
Joined Dec 26, '02
From Alabama
I'm with you man.
post Mar 28, 2003 - 1:02 AM
bonzaisushi
Joined Oct 3, '02
From bonzaisushi@hotmail.com
ive talked to some guys on celica.net who have turboed there cars, and they have ran up to 20 psi on the 5sfe, without problems, and that put more than 250 out, im sure they did a little work on the engine but not alott from what ive heard.
Lo-Fi Version Time is now: February 26th, 2025 - 12:50 PM
