> Erratic Idling, help me!
post Jan 10, 2005 - 10:47 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
Hey everyone, my engine idles real strangely. I start the engine and everything runs fine and I can drive the car, but when I put the car into neutral or park, the engine revs up to 2k as its idle and then bounces between 2k-3k like mad. It sounds like my car is gonna tear itself to pieces!! Whats wrong? Im thinking it has to do with engine timing and if it is how can I adjust it?
Replies (1 - 15)
post Jan 10, 2005 - 11:18 PM
biglipzit
Joined Dec 13, '04
From St. Lucia
It probrably is timing i would think. I only ever adjusted the timing on a ka24de but that was done using a timing light on the main pulley and the timing marks and then twisting the distributor from left to right ti adjust the timing. Not sure if toyota engines are the same but i am sure google would have all the info for adjusting the timing on your specific engine.
lol just kidding about the pic!!
post Jan 10, 2005 - 11:33 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i think there is an idle controller to when you put it in park. you have OBD I. does it throw a check engine at all.
post Jan 10, 2005 - 11:51 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
nope no check engine lights at all. everything seems fine until I put the car into park or neutral and then it goes nuts
post Jan 10, 2005 - 11:56 PM
hard to say...maby something is wrong with the o2 sensor?
post Jan 11, 2005 - 5:25 AM
Rjb23
Joined Feb 8, '04
From KY
I doubt its timing, you could have a bad sensor or an air leak somewhere causing it to run lean and idle higher than it should.
post Jan 11, 2005 - 11:17 AM
neoklis
Joined Oct 24, '03
From Cyprus
When did you last take it for a service? it can be dirty injectors/fuel filter or even sparks(though i doubt it)
Try driving it hard for 10-15 minutes to clean up the fuel system.
I am no expert but my Curren had similar problem with high CO2 and the inspector told me to drive it hard for a few minutes and then come back, and what you know that fixed the problem.
post Jan 11, 2005 - 2:31 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
Well I just dropped my car off at Longo Toyota where my friend works so I guess I'll see whats wrong.
post Jan 11, 2005 - 5:55 PM
Anub1s
Joined Nov 27, '03
I'm putting my money on Vaccuum leak.
post Jan 11, 2005 - 6:34 PM
Newbie
Joined Nov 3, '04
From Colorado
Maybe the IAC vacuum pump is pushing air in?
post Jan 11, 2005 - 11:35 PM
Junior
Joined May 5, '03
From Toronto
its the Idle air control valve. Its a common problem with honda's and acura's, so I've seen it many times.
post Jan 11, 2005 - 11:41 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
that was exactly what i was talking about but i couldn't remember the name.
post Jan 13, 2005 - 2:43 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
Yep Junior and rjbibeau were right. My friend said my Idle Air Control Valve was messed up and I got it replaced and now everything is hunkey dory again biggrin.gif
*Well everyone is kind right because I also got a tune up and got just about everything replaced tongue.gif*
This post has been edited by hellsyphon: Jan 13, 2005 - 2:48 PM
post Jan 14, 2005 - 6:04 AM
Newbie
Joined Nov 3, '04
From Colorado
You suck for not mentioning me.. tongue.gif This is what I get for trying to help. Ha ha.. I kid.
post Jan 14, 2005 - 8:51 AM
sapperk
Joined Mar 9, '03
From Orting, WA
Mine does the same thing except it idles real low when im in neutral. like 100-200rpms.
where is the Idle air control valve
post Jan 14, 2005 - 9:59 AM
toyotatech3
Joined Jul 30, '04
From colorado
it's under the throttle body
Lo-Fi Version Time is now: January 10th, 2025 - 1:35 AM
