> 3s-gte 3rd gen + ECU, ebay again
post Jan 11, 2005 - 7:55 PM
spunky393
Joined Apr 22, '04
From illinois
3s-gte - buy it now for 2800
what's the problem with this?
The most important lesson I learned from Karate-Dō Kyōshan“You can not be what you do not believe you are”
Replies (1 - 11)
post Jan 11, 2005 - 10:26 PM
problem 1:
its just an engine
problem 2:
the harness is from a rwd mr2
problem 3:
no one here knows how to do mr2 - celica wiring
post Jan 11, 2005 - 10:43 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
QUOTE(lagos @ Jan 12, 2005 - 3:26 AM)
problem 1:
its just an engine
problem 2:
problem 3:
[right][snapback]232647[/snapback][/right]
I though you can use the MR2 wiring, it just has to be extended? Also, I'm sure that the wiring is possible, just difficult. With the right diagrams, it can be done.
post Jan 11, 2005 - 11:04 PM
all the the 3sgte harnesses need to be rewired ..its not just extending. you need to rewire the main engine fuse box and the interrior plugs, then extend the harness or cut a new hole in the firewall.
post Jan 11, 2005 - 11:19 PM
spunky393
Joined Apr 22, '04
From illinois
so does that make this a good buy lagos?
post Jan 11, 2005 - 11:26 PM
isnt XXXmina's an MR2 3rd Gen?
post Jan 11, 2005 - 11:27 PM
no not at all.... those types of engine deals are only good if your original engine was a 3sgte, died, and just just want to put the same thing back in.
in the auction, they say youll get engine, tranny, and harness....but you dont get the AFM, ignitor, coil, resisotor packs,misc hoses, etc... you need all those things for your car to run.
always buy a clip for your 1st swap.
post Jan 11, 2005 - 11:28 PM
theres no AFM for 3rd gen its MAP.
post Jan 11, 2005 - 11:30 PM
spunky393
Joined Apr 22, '04
From illinois
Explain the AFM
edit: please
This post has been edited by spunky393: Jan 11, 2005 - 11:30 PM
post Jan 11, 2005 - 11:50 PM
Air Flow Meter - measures how much air is entering the engine, located right after the intake filter & before the compressor.
The 3rd Gen 3s Ecu's dont utilize this.
post Jan 12, 2005 - 7:17 PM
doh...my bad...forgot it was 3rd gen.
post Jan 12, 2005 - 7:24 PM
Plus you need to realize that when they say uncut wiring harness, chances are that it's cut up.
Lo-Fi Version Time is now: December 2nd, 2024 - 10:56 PM
