Flywheel question |
Flywheel question |
Mar 27, 2003 - 2:30 PM |
I'm looking to get a Fidanza flywheel for my car. I'm doing the swap to 3sgte and Im wondering if an MR2 3sgte flywheel will fit?
Mar 27, 2003 - 4:29 PM |
Enthusiast Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
yes. it will work, as long as you are using a 90-93 3sgte, it may work for the 94-98, but i'm not positive about that.
-------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Mar 27, 2003 - 5:57 PM |
Enthusiast Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
I don't know all that muc habout parts, but what does a flywheel do? and where is it located?
Mar 27, 2003 - 6:53 PM |
Enthusiast Joined Sep 5, '02 From Phoenix, AZ Currently Offline Reputation: 0 (0%) |
A flywheel is the part that spins around in the transmission and when the clutch touches it, the flywheel causes the clutch to spin, making your axles turn giving you momentum. Or something like that. Check this out for a better expaination... http://www.howstuffworks.com
As for a high performance flywheel for the 3sgte you should get a JUN Flywheel. It's like less than 10lbs and is made of titanium so that makes it hella strong. |
the flywheel is what the clutch interacts with. the flywheel is on the crankshaft axis, and spins with the engine. the clutch plate approaches the flywheel when you press the clutch pedal, and when the meet, the spinning (power) is transferred from the flywheel to the clutch to the drivetrain. a lighter flywheel helps rotation and acceleration. -------------------- 1994 Lexus ES300
Mar 27, 2003 - 7:56 PM |
Enthusiast Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
by reducing the weight of the flywheel you don't increase engine HP but HP at wheels cause the reduction of any rotating mass let the engine work faster cause it has less weight to move
Mar 27, 2003 - 9:01 PM |
ya i have that flywheel on order.
i got all the internal parts for the 3s-gte from jun like 6 g's later |
Lo-Fi Version | Time is now: December 4th, 2024 - 4:00 PM |
